Date/Time: Fri, 18 Oct 2024 04:00:19 +0000
How do I copy charts/studies and all other settings to new instance?
View Count: 198
[2024-06-22 18:11:12] |
User429142 - Posts: 42 |
Before posting I used the search and found this Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation but it talks about installing sierra on another computer or "another folder". I don't feel I am doing this because the sierrchartinstance_2 folder is within C:\SierraChart Before I go messing up hours of work I want to clarify I am taking the right steps before continuing. Take a look at this screen shot. I was just going to take all these highlighted folders and overwrite the contents of those folders within the C:\SierraChart\SierraChartInstance_2 folder. Is this the correct way to go about transferring everything over? EDIT: Nevermind I just did it and it worked. i don't need help Date Time Of Last Edit: 2024-06-23 19:27:56
Screenshot_3.jpg / V - Attached On 2024-06-22 18:07:43 UTC - Size: 525.89 KB - 49 views |
[2024-07-09 03:45:59] |
Sierra_Chart Engineering - Posts: 16656 |
That is a sub instance folder. The easiest thing to do is to exit from sub instance 2. Delete this folder: C:\SierraChart\SierraChartInstance_2 And then run the substance again through File >> New Instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-09 03:46:21
