Date/Time: Sun, 24 Nov 2024 04:26:30 +0000
CME with Market Depth for non-professional trading accounts
View Count: 220
[2024-06-22 12:18:11] |
User374635 - Posts: 5 |
I currently use the Denali data feed for Eurex exchange without being integrated with any particular trading service and so my data/trade service is set to SC Data - All Services. I would now also like to look into some CME products via the 'CME with Market Depth for non-professional Trading accounts'. To access realtime market data at lower priced nonprofessional fees I set up an account with Stage 5 and whilst the money is being deposited I was hoping to get some clarification on the next steps: Complete the exchange agreements and activate exchange. (Is there any other link that needs to be established between sierra and stage 5 or is the recognition of an account with funds automatic?). Update Sierra to the latest version. On global settings set service to teton cme order routing with clearing firm set to stage 5. File - connect to data feed. To match existing DAX chartbook with new service - translate symbols to current service. (Will the data I receive for eurex change in anyway when switching from SC Data - All services to Teton cme order routing or are both coming via Denali and so no change? Ie can I expect the values I currently see for the Dax to remain consistent through this service change?) Thanks in advance. |
[2024-06-24 14:20:55] |
You also need to connect to the account with Stage 5. You will not get the real-time data until you have made this connection. The instructions for setting up the Teton Order Routing Service is at the following link. Follow these instructions to get setup. Sierra Chart Teton Futures Order Routing: Setup Instructions Will the data I receive for eurex change in anyway when switching from SC Data - All services to Teton cme order routing or are both coming via Denali and so no change? Ie can I expect the values I currently see for the Dax to remain consistent through this service change?
Nothing will change. The EUREX data is coming from us in both cases and therefore is exactly the same. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
