Date/Time: Sun, 08 Sep 2024 00:05:39 +0000
Automatically Rollover Futures Symbol - Volume Based, Backadjusted
View Count: 130
[2024-06-21 22:20:13] |
User12791 - Posts: 1 |
Hello, If I choose the "Continuous Futures Contract - Volume Based Rollover, Back Adjusted" option and toggle the "Automatically Rollover Futures Symbol" to "Yes", will it auto rollover that contract based volume or does that auto rollover feature only work on "Date Rule" setting option? Thanks |
[2024-06-25 19:09:25] |
Sierra_Chart Engineering - Posts: 16292 |
The choice of the "Continuous Futures Contract" type does not control the rollover for the current contract - it affects how the historical data is handled from contract to contract. For information about how Automatically Rollover Futures Symbol works, refer to: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-25 19:09:54
