Date/Time: Wed, 27 Nov 2024 08:40:39 +0000
No Difference in Volume Charts
View Count: 961
[2014-08-23 10:52:55] |
Richard Novak - Posts: 24 |
Hello, I'm currently using volume charts and have noticed that when using large volume per bar values that two charts with different volume per bar values can display exactly the same chart. For example, I have two charts for the CL futures contract where the volume per bar for one is 262144 volume and the other is 1048576 volume. The second chart has a volume per bar value that is 4 times the first one but yet, the charts displayed are identical. Could you explain why this is the case and if there is something I can do to correct the problem. Thank you, Richard Novak |
[2014-08-24 00:33:59] |
You need to uncheck Chart >> Chart Settings >> New Bar at Session Start.
