Date/Time: Fri, 18 Oct 2024 04:16:48 +0000
Watch List Symbols Changing
View Count: 136
[2024-06-21 15:20:38] |
User352530 - Posts: 6 |
Hello, I use a watch list in a control bar to switch between symbols on a chartbook, and I cannot figure out how to keep the symbols in the watch list constant. Sometimes it will re-add symbols that I have previously removed from the watchlist. Other times, it will switch to the wrong contract for a product (ie, this morning many of my symbols changed from "U" to "M". Any advice is appreciated. Thank you, |
[2024-06-21 16:43:28] |
John - SC Support - Posts: 35333 |
The main thing we want to point out is that the watch list in the control bar is going to change the list of symbols available when you change the active chart. In other words, the active chart's list of Associated Watch List symbols will be what is in the list. Another possibility is that you did not save the chartbook after changing the Watch List, which resulted in the previous settings returning when you opened the chartbook again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
