Date/Time: Wed, 23 Sep 2026 08:27:47 +0000
Spreadsheet Trading System
View Count: 522
[2024-06-21 14:03:57]
User357489 - Posts: 72
Hi there, at present i have buy and sell conditions for auto entry based on 1 condition. i wanted to know if i were to use the =OR(AND... formula, i could have several different conditions, so if 1 or more occur at any given time, they trigger the trade.
my current formula is
=AND(ABS($J$8)=0, EA3<EA4, EH3<EH4, EJ3>EJ4, EK3>EK4, E3>C4, EH3>0, E3>C4,FL3>FL4, A3-INT(A3)>TIMEVALUE("01:30:00"))
can i simply add to this list using commas as seperators, and would i just need to add =or(and...?
[2024-06-21 14:26:34]
John - SC Support - Posts: 47980
Yes, you can do what you are wanting. For example:
=OR(AND(item1, item2, item3), AND(item4, item5, item6))
[2024-06-23 14:22:27]
Hi John
Thanks, it's worked for the most part.
As I was tweaking and testing in chart replay, I have noticed that some cell references changed?
So when I wrote a condition let's say, EJ3>0 denoting ID15.SG1 >0, as I was watching the replay, I noticed it wasnt triggering in some places so checked and in this example, had gone to cell column EH instead.
If I then remove say 1/3 of my conditions to test the remaining, it actually doesn't seem to then recognize the new buy/sell entry formula and feels like I have to start from scratch?
Quite confusing, hoping you can shed light if similar things happened to others in past.
Appreciate the help as always
[2024-06-23 14:30:41]
For further reference, here are the 3 individual conditions I want to combine into one buy/sell entry formula:
1) =AND(AO3>0, E3>C4, DY3>DY4, EJ3>EJ4, EK3>EK4, FL3>FL4, EH3>0
2)=AND(ABS($J$8)=0, EA3<EA4, EH3<EH4, EJ3>EJ4, EK3>EK4, E3>C4, EH3>0, E3>C4,FL3>FL4, A3-INT(A3)>TIMEVALUE("08:30:00
3) =OR(AND(ABS($J$8)=0,CROSSFROMBELOW(AJ3:AJ4,AK3:AK4),E3>=AI3,EA3>0, A3-INT(A3)>TIMEVALUE("08:30:00")))
Where $J$8 is the 'position quantity' cell.
I asked chat gpt to combine all 3 using =OR(AND as you answered in a previous support ticket, yet I feel this is where I went wrong as I'm not totally confident writing the formulas 'solo:
[2024-06-24 17:01:07]
We think what you are referencing is that the columns that hold the other study values will change as you add/remove studies. This is the case with the Spreadsheet Study and is why we recommend using the format specified at the following link to reference studies within a Spreadsheet:
Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study
