Date/Time: Sun, 08 Sep 2024 00:23:28 +0000
Study need to load 11 times to get works
View Count: 121
[2024-06-20 19:17:10] |
User129860 - Posts: 33 |
Hi Support, I know this is odd, but I have a study that need to load untill 11 time then it works, other wise it doesnt. This happen only when I login through teton routing via my broker. If I login via Bulenox or apex...then it works fine |
[2024-06-20 20:00:24] |
If that is a custom study, then you would need to ask the developer of the study about this. If that is one of the built-in studies, then we need to know which one (you have "Volume Weighted Average Price" highlighted - is it this?). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-20 23:21:52] |
hi Support, no, it's a custom study. Anyway I found the problem. Thanks for your prompt response! |
