Date/Time: Sun, 24 Nov 2024 06:21:08 +0000
Suggested improvement for the transparent highlight
View Count: 193
[2024-06-20 15:14:34]
User166108 - Posts: 73
Use session start/end time from the chart as that is probably 80% of the use cases. I just copied from ACS_Source and tweaked it to use session start time. Obviously you'd still want to allow a specified start/end time.
SCSFExport scsf_SessionTimeRangeHighlightTransparent(SCStudyInterfaceRef sc)
SCSubgraphRef Subgraph_TimeRange = sc.Subgraph[0];
SCInputRef ForwardProject = sc.Input[1];
if (sc.SetDefaults)
sc.GraphName = "Time Range Highlight - Transparent";
sc.GraphRegion = 0;
sc.AutoLoop = 0; // Manual looping
sc.ValueFormat = 0;
sc.ScaleRangeType = SCALE_SAMEASREGION;
sc.DrawStudyUnderneathMainPriceGraph = true;
Subgraph_TimeRange.Name = "TR";
Subgraph_TimeRange.DrawStyle = DRAWSTYLE_BACKGROUND_TRANSPARENT;
Subgraph_TimeRange.PrimaryColor = RGB(64, 64, 64);
Subgraph_TimeRange.DrawZeros = false;
ForwardProject.Name = "Display in Forward Projection Area";
ForwardProject.SetYesNo(false);
return;
n_ACSIL::s_ChartSessionTimes sessionTimes;
sc.GetSessionTimesFromChart(sc.ChartNumber, sessionTimes);
int NumberForwardBars = 0;
if (ForwardProject.GetYesNo())
NumberForwardBars = 200;
Subgraph_TimeRange.ExtendedArrayElementsToGraph = NumberForwardBars;
for (int Index = sc.UpdateStartIndex; Index < (sc.ArraySize + NumberForwardBars); Index++)
SCDateTime &IndexDateTime = sc.BaseDateTimeIn[Index];
bool ShouldHighLight = false;
ShouldHighLight = (IndexDateTime.GetTimeInSeconds() >= sessionTimes.StartTime.GetTime() && IndexDateTime.GetTimeInSeconds() <= sessionTimes.EndTime.GetTime());
if (ShouldHighLight)
Subgraph_TimeRange[Index] = 1;
else
Subgraph_TimeRange[Index] = 0;
