Date/Time: Sun, 24 Nov 2024 07:02:00 +0000
Footprint trading lots error
View Count: 171
[2024-06-20 14:29:39] |
hamboz - Posts: 16 |
My NQ footprint chart candles only shows trading lots in single digits only for e.g. 6X7. My Volume at Price multiplier is also set at 1. Refer to the attachment
trading lots error.PNG / V - Attached On 2024-06-20 14:29:33 UTC - Size: 291.79 KB - 46 views |
[2024-06-20 15:05:31] |
Make sure the Numbers Bars Input for "Volume Display Multiplier" is set to 1. Refer to the following: Numbers Bars: Volume Display Multiplier For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-20 15:08:18] |
It's already set to 1. I just noticed that if the actual lots are 126X238, my footprint will show 6X2 so last digit of the bid lot and first digit of the ask lot
[2024-06-20 15:14:20] |
This sounds like a spacing issue. Increase the bar spacing to be able to view all of the information. Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
