Date/Time: Wed, 27 Nov 2024 08:41:02 +0000
help
View Count: 966
[2014-08-23 07:45:39]
User67228 - Posts: 1
I try to connect SC demo to data feed , but I see only the text below
Software version: 1174 | 2014-08-23 02:20:19
Your usage time has ended. You are in FREE MODE. Features are restricted. | 2014-08-23 02:20:19
To purchase more time select Help>>Purchase on the menu. | 2014-08-23 02:20:19
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-23 02:20:19
Active service: CTS T4 FIX | 2014-08-23 02:20:19
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-08-23 02:20:19
2014-08-23 09:20:19 Local computer clock time | 2014-08-23 02:20:19
2014-08-23 07:20:19 GMT time | 2014-08-23 02:20:19
2014-08-23 02:20:19 Time zone adjusted time | 2014-08-23 02:20:19
Time difference to server time: 1 seconds. | 2014-08-23 02:20:19
Program path: C:\SierraChart\ | 2014-08-23 02:20:19
Data Files path: C:\SierraChart\Data\ | 2014-08-23 02:20:19
OS Version Number: 6.2 | 2014-08-23 02:20:19
Checking for new symbol settings for cts | 2014-08-23 02:20:19
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-08-23 02:20:19
HTTP connection to www.sierrachart.com:80 (1080) | Connected. | 2014-08-23 02:20:19
Symbol settings are up-to-date for cts | 2014-08-23 02:20:19
Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-23 02:20:24
HTTP connection to www.sierrachart.com:80 (1080) | Closed. No error. | 2014-08-23 02:20:29
HTTP connection to www.sierrachart.com:80 (1080) | Shutdown and closed. | 2014-08-23 02:20:29
A request for the latest software update has been made. | 2014-08-23 02:20:55
The update is being downloaded in the background. When it is complete, you will be prompted. | 2014-08-23 02:20:55
There is no new version available. Thank you. | 2014-08-23 02:20:55
Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-23 02:21:09
Date Time Of Last Edit: 2014-08-23 23:57:41
Private File
[2014-08-23 23:57:51]
Your account has been activated and/or reset.
A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit".
