Date/Time: Sun, 24 Nov 2024 06:45:20 +0000
Real time data from Mexican Stock Exchange
View Count: 145
[2024-06-19 19:20:34] |
User674409 - Posts: 24 |
Is there a way to receive real-time data from the Mexican stock exchange through Sierra Chart?
[2024-06-19 19:28:01] |
Check with your broker to see if they have this data available or if it is available through the order routing service they are using. If you just want to use Sierra Chart for charting, then you can see if DTN IQ Feed has this data and get it from them, as we can get data from them into the system. Refer to the following: DTN IQ Feed Data Service Our servers show that you are connected to our Teton Order Routing Service. This service only works with the CME Group, so if you are wanting to trade the Mexican Stock Exchange, you would need to use a different brokerage account for this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-19 19:28:10
