Date/Time: Wed, 27 Nov 2024 08:43:02 +0000
how do I add date separator in the charts
View Count: 2904
[2014-08-22 20:42:24] |
dp7 - Posts: 26 |
How do I add the vertical lines to separate each trading day? Thanks |
[2014-08-22 21:26:06] |
User13668 - Posts: 294 |
Time Line study would be your solution. http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s181 |
[2014-08-22 21:43:15] |
Refer to the documentation for the Vertical Grid here: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#Vgrid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-22 22:12:58] |
dp7 - Posts: 26 |
TNX for the help!
