Date/Time: Sun, 24 Nov 2024 06:39:35 +0000
[User Discussion] - modifying attached orders
View Count: 195
[2024-06-19 15:27:22] |
User606716 - Posts: 2 |
I am no longer able to modify my attached orders. What could cause this problem?
[2024-06-19 15:35:07] |
We need more information. How are you trying to modify the attached orders? What happens when you try to modify them? Are you getting an error of some kind? Check to make sure that "Trade Locked" is not enabled and that "Chart Trade Mode On" is enabled. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
