Date/Time: Sun, 24 Nov 2024 06:38:35 +0000
Is there a way to get the documentation in PDF?
View Count: 223
[2024-06-19 15:15:42] |
User799255 - Posts: 24 |
I know there is an HTML download but is there a PDF version? or is there a reliable way to convert that I can get some advice on doing? Google has an AI product called NotebookLM, an AI-powered research and writing assistant that can answer your questions chatgpt style using the reference you provide. But it doesn't take in nested HTMLs, only PDFs. I strongly believe it is the most obvious way to leverage AI, for now, to make the most out of Sierra Chart. |
[2024-06-19 15:33:11] |
We do not have the documentation in a PDF format.
[2024-06-19 21:57:47] |
ForgivingComputers.com - Posts: 960 |
You can use MS Word to open the HTML file and then File>>Export..>>pdf |
