Date/Time: Sun, 24 Nov 2024 06:19:28 +0000
Data Accuracy - Volume Profile Value Area
View Count: 306
[2024-06-19 05:39:06]
User556806 - Posts: 15
I've noticed that that there are big differences between Sierra Chart and Tradingview chart, regarding Volume Profile Value Areas. I've snipped today's AAPL charts from both platform and the same time frame charts (15-min) look quite different. And it seems Sierra Chart's value area doesn't make sense to me. Has anyone experienced this? What reason could it be?
imageAAPL_Tradingview.JPG / V - Attached On 2024-06-19 05:33:37 UTC - Size: 134.67 KB - 49 views
imageAAPL_Sierra.JPG / V - Attached On 2024-06-19 05:38:00 UTC - Size: 113.96 KB - 58 views
[2024-06-19 10:58:54]
Sierra_Chart Engineering - Posts: 17154
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
[2024-06-19 12:21:22]
Does this mean it's only accurate when it's tick chart?
[2024-06-19 12:46:49]
Yes it is not completely accurate unless the data is tick by tick.
And we will never make any comparisons to another program. That is not within the scope of our support at all.
[2024-06-19 15:28:29]
VLiviu - Posts: 223
@User556806 , Tradingview does not provide tick by tick data unless you pay for it.
