Date/Time: Sun, 24 Nov 2024 06:58:32 +0000
How to prevent an alert from firing more than once every x minutes?
View Count: 220
[2024-06-19 00:01:19] |
jsandlan - Posts: 46 |
I'm using the Color Bar Based On Alert Condition study to fire an alert when a set of conditions are true. The alert tends to fire frequently and I would like to only allow it to fire 1 time in every 15 minute interval. Is it possible to set the frequency of an alert from the Color Bar Based On Alert Condition study for every x minutes? Thanks, Jackson |
[2024-06-19 14:24:55] |
There is not a way to do this directly within the study or by using the alerts. You might be able to do this using the Spreadsheet study to give you a switch that you can reference, but you would have to be careful about either a race condition or a circular reference. Refer to the following for a starting place: Spreadsheet Example Formulas and Usage: Buy on First Signal and Ignore Multiple Signals For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-19 16:15:10] |
Is the Color Bar Based On Alert Condition study code available in the Sierra Chart directory? Would preventing an alert from firing more than once per x minutes be possible using a custom ASCIL study? I was thinking about adding additional functionality to the Color Bar Based On Alert Condition study and creating a custom study that allows throttling the alert. Jackson |
[2024-06-19 17:50:41] |
The "Color Bar Based on Alert Condition" study source code is NOT available. But a custom study would allow you to do what you want, as it can keep track of the information you need through a persistent variable. Refer to the following: sc.GetPersistentIntFromChartStudy() List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
