Date/Time: Wed, 27 Nov 2024 08:36:02 +0000
numbers bars don't display correctly
View Count: 977
[2014-08-22 19:40:03]
kkinner - Posts: 5
Hi - I have an Infinity account and the numbers bars indicator in the program doesn't seem to work correctly. I have the level 5 package enabled, but as you can see from the attached images, the numbers bars seems hyper-compressed. It's not possible to expand far enough to make them look like the usual numbers bars. The second images reflects the expanded view - still messed up. Any thoughts?
Private File
Private File
[2014-08-22 21:41:19]
The problem is that you are missing the Symbol Settings. Perform a Full Reset of the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps
After this is done apply them to that chart. The procedure is documented at the bottom of the same page:
