Date/Time: Sun, 24 Nov 2024 06:05:17 +0000
Chart Ratio Spread
View Count: 168
[2024-06-18 16:35:01]
User841161 - Posts: 221
Can you chart ratio future option spreads? Was wanting to try and chart the 1X2 5540-5520 put options spread. So would be buying 1 ES 5540P and Selling 2 ES 5520P. If so what would be the best way of doing so? Didn't know if maybe use the subtraction study or maybe creating a custom symbol.
[2024-06-18 17:01:10]
You would have to use the "Custom Calculated Symbols" to do this. Refer to the following:
