Date/Time: Sun, 24 Nov 2024 05:20:20 +0000
Specify Rollover DATE
View Count: 175
[2024-06-18 14:15:26] |
User299107 - Posts: 55 |
Hi, is is possible to set the actual date for chart date to rollover - eg say rollover is the 21st of June and I want the charts to roll on 18th June... Thanks, Eliza |
[2024-06-18 14:58:18] |
There is an option to control the number of days to adjust the rollover, but this applies to all rollovers, not just to a single symbol. Refer to the following: General Settings Window: Additional Days to Add to Rollover Date for Chart and Quote Board Rollovers (Global Settings >> General Settings >> Charts >> Charts) Another option would be to edit the symbol settings and adjust the "Rollover Method". Refer to the following: Global Symbol Settings: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
