Date/Time: Sun, 24 Nov 2024 05:25:04 +0000
Large Volume Trade Indicator
View Count: 178
[2024-06-18 14:01:59] |
User731023 - Posts: 138 |
I have 2 charts with the same Large Volume Trade Indicator on them. Same computer and settings. Same setting for a fact. Used my set default for both and triple checked settings. Also same bars and days. Also session times and chart update. I for the life of me can not figure out why they do not show the same as seen on snapshot provided. Please advise. |
[2024-06-18 14:55:12] |
Are the charts exactly the same as well? Same starting dates, same data? In particular, check the setting for "Chart >> Chart Settings >> Chart Data >> Combine Trades into Original Summary Trade" and make sure this is set the same for both. Refer to the following: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) There are many other chart settings that can affect this, so you need to check all of them. The easiest thing would be to duplicate one of the charts and then verify that the "Large Volume Trade Indicator" is showing the same in both of those charts. If they are, then there is something different in the chart settings. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
