Date/Time: Wed, 27 Nov 2024 08:46:19 +0000
Tick candlesticks
View Count: 1023
[2014-08-22 18:59:12] |
ripsdips - Posts: 143 |
are there non renko tick charts? Tick charts with candlesticks?
[2014-08-22 23:46:15] |
Yes this is supported. What you are referring to is Bar Periods Type >> Number of Trades Per Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
