Date/Time: Sun, 24 Nov 2024 06:23:15 +0000
connectivity with Teton
View Count: 194
[2024-06-18 13:58:32] |
User653934 - Posts: 28 |
I keep getting an error message on my instance one that Teton CME order routing is not authorized. Invalid account name or password. I've reset my password and still get the same issue on Instance 1. Instance 2 seems to be fine. Not sure what else to do. S. It seems to be working now. I fussed with it some more. I have two icons to open Sierra Chart and had to set the password for both...Maybe that was the problem. Anyway, its resolved I think. Thanks anyway. S. |
[2024-06-18 14:23:17] |
Sierra_Chart Engineering - Posts: 17154 |
If you need more help we need to see the Message Log. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-19 13:48:34] |
2024-06-19 09:42:25.066 | Software version: 2634 64-bit 2024-06-19 09:42:25.066 | Primary Thread ID: 16644 2024-06-19 09:42:25.066 | Usage end date: 2024-10-02 2024-06-19 09:42:25.066 | Enabled for: Advanced Features 2. 2024-06-19 09:42:25.066 | Enabled for: Sierra Chart Historical Data Service. 2024-06-19 09:42:25.066 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-06-19 09:42:25.066 | Enabled for: Delayed Denali Exchange Data Feed. 2024-06-19 09:42:25.066 | Enabled for exchange2: CME (Trading Account Required) 2024-06-19 09:42:25.066 | Enabled for exchange2: CBOT (Trading Account Required) 2024-06-19 09:42:25.066 | Enabled for exchange2: COMEX (Trading Account Required) 2024-06-19 09:42:25.066 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-06-19 09:42:25.066 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-06-19 09:42:25.066 | Current selected Data/Trading service: DTC - Sub Instance 2024-06-19 09:42:25.066 | Custom symbol settings values: enabled 2024-06-19 09:42:25.066 | Chart Update Interval: 500 2024-06-19 09:42:25.066 | Intraday Data Storage Time Unit: 1 2024-06-19 09:42:25.066 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2024-06-19 09:42:25.066 | 2024-06-19 13:42:25 Local computer time in UTC 2024-06-19 09:42:25.066 | 2024-06-19 09:42:25 Local computer time in SC Time Zone 2024-06-19 09:42:25.066 | 2024-06-19 13:39:24 Server time in UTC 2024-06-19 09:42:25.066 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-06-19 09:42:25.066 | Program path: C:\SierraChart\SierraChartInstance_2\ 2024-06-19 09:42:25.066 | Data Files path: C:\SierraChart\SierraChartInstance_2\Data\ 2024-06-19 09:42:25.066 | OS Version Number: 10.0 2024-06-19 09:42:25.066 | Locale Setting: C 2024-06-19 09:42:25.071 | DLLs: UserContributedStudies_64.dll 2024-06-19 09:42:25.071 | Allowed protected custom studies: 2024-06-19 09:42:25.071 | Crash reporter started: true 2024-06-19 09:42:25.071 | 2024-06-19 09:43:17.158 | File >> Disconnect selected. 2024-06-19 09:43:17.192 | DTC - Sub Instance | Waiting for socket receive thread to end 2024-06-19 09:43:17.198 | DTC Client socket (1) | CloseSocket call. 2024-06-19 09:43:17.198 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:17.199 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-19 09:43:17.199 | DTC Client socket (1) | Closed. 2024-06-19 09:43:17.201 | DTC - Sub Instance | Disconnected. 2024-06-19 09:43:22.522 | 2024-06-19 09:43:22.523 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-06-19 09:43:22.523 | DTC Client socket (1) | Creating socket. 2024-06-19 09:43:22.523 | DTC Client socket (1) | New receive buffer size: 0 2024-06-19 09:43:22.523 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-06-19 09:43:22.529 | DTC - Sub Instance | Network connection to server complete. 2024-06-19 09:43:22.529 | DTC - Sub Instance | Starting socket receive thread. 2024-06-19 09:43:22.529 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2024-06-19 09:43:22.590 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2024-06-19 09:43:22.590 | DTC - Sub Instance | Sending logon request message. 2024-06-19 09:43:22.642 | DTC - Sub Instance | Received logon response. 2024-06-19 09:43:22.642 | DTC - Sub Instance | Server Name: SC DTC Server. Build=50081. 2024-06-19 09:43:22.642 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2024-06-19 09:43:22.642 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading. 2024-06-19 09:43:22.642 | DTC - Sub Instance | Trading is supported. 2024-06-19 09:43:22.642 | DTC - Sub Instance | Order cancel and replace is supported. 2024-06-19 09:43:22.642 | DTC - Sub Instance | OCO Orders supported. 2024-06-19 09:43:22.642 | DTC - Sub Instance | Bracket Orders supported. 2024-06-19 09:43:22.642 | DTC - Sub Instance | MarketDepthIsSupported: 1 2024-06-19 09:43:22.642 | DTC - Sub Instance | Connected to server complete. 2024-06-19 09:43:22.688 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-06-19 09:43:22.688 | Subscribing to symbol for symbol alert. 6EM24 2024-06-19 09:43:22.688 | Using symbol data fast lookup vector 2024-06-19 09:43:22.688 | DTC - Sub Instance | Starting real-time market data updates for: 6EM24. ID: 1 2024-06-19 09:43:22.688 | DTC - Sub Instance | Requesting security definition data for: 6EM24. ID: 1 2024-06-19 09:43:22.688 | Subscribing to symbol for symbol alert. HEM24_FUT_CME 2024-06-19 09:43:22.695 | DTC - Sub Instance | Starting real-time market data updates for: HEM24_FUT_CME. ID: 2 2024-06-19 09:43:22.695 | DTC - Sub Instance | Requesting security definition data for: HEM24_FUT_CME. ID: 2 2024-06-19 09:43:22.734 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 2. 2024-06-19 09:43:22.738 | DTC - Sub Instance | Received security definition for symbol 6EM24 2024-06-19 09:43:22.738 | DTC - Sub Instance | Received security definition for symbol HEM24_FUT_CME 2024-06-19 09:43:22.770 | DTC - Sub Instance | Starting real-time market data updates for: MESU24_FUT_CME. ID: 3 2024-06-19 09:43:22.770 | DTC - Sub Instance | Requesting security definition data for: MESU24_FUT_CME. ID: 3 2024-06-19 09:43:22.773 | Added historical Intraday data request for MESU24_FUT_CME to the queue. 2024-06-19 09:43:22.773 | Intraday data recording state for symbol MESU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:22.776 | Triggering next historical data download in queue. 2024-06-19 09:43:22.836 | Delaying start of download for MESU24_FUT_CME. 2024-06-19 09:43:22.849 | DTC - Sub Instance | Received security definition for symbol MESU24_FUT_CME 2024-06-19 09:43:22.855 | DTC - Sub Instance | Starting real-time market data updates for: M2KU24_FUT_CME. ID: 4 2024-06-19 09:43:22.855 | DTC - Sub Instance | Requesting security definition data for: M2KU24_FUT_CME. ID: 4 2024-06-19 09:43:22.855 | Added historical Intraday data request for M2KU24_FUT_CME to the queue. 2024-06-19 09:43:22.855 | Intraday data recording state for symbol M2KU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:22.855 | Triggering next historical data download in queue. 2024-06-19 09:43:22.895 | DTC - Sub Instance | Received security definition for symbol M2KU24_FUT_CME 2024-06-19 09:43:22.903 | DTC - Sub Instance | Starting real-time market data updates for: LEQ24_FUT_CME. ID: 5 2024-06-19 09:43:22.903 | DTC - Sub Instance | Requesting security definition data for: LEQ24_FUT_CME. ID: 5 2024-06-19 09:43:22.903 | Added historical Intraday data request for LEQ24_FUT_CME to the queue. 2024-06-19 09:43:22.903 | Intraday data recording state for symbol LEQ24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:22.903 | Triggering next historical data download in queue. 2024-06-19 09:43:22.950 | DTC - Sub Instance | Received security definition for symbol LEQ24_FUT_CME 2024-06-19 09:43:22.962 | DTC - Sub Instance | Starting real-time market data updates for: ZMN24_FUT_CME. ID: 6 2024-06-19 09:43:22.963 | DTC - Sub Instance | Requesting security definition data for: ZMN24_FUT_CME. ID: 6 2024-06-19 09:43:22.985 | DTC - Sub Instance | Received security definition for symbol ZMN24_FUT_CME 2024-06-19 09:43:23.019 | DTC - Sub Instance | Starting real-time market data updates for: 6EU24_FUT_CME. ID: 7 2024-06-19 09:43:23.019 | DTC - Sub Instance | Requesting security definition data for: 6EU24_FUT_CME. ID: 7 2024-06-19 09:43:23.019 | Added historical Intraday data request for 6EU24_FUT_CME to the queue. 2024-06-19 09:43:23.019 | Intraday data recording state for symbol 6EU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.019 | Triggering next historical data download in queue. 2024-06-19 09:43:23.028 | DTC - Sub Instance | Received security definition for symbol 6EU24_FUT_CME 2024-06-19 09:43:23.061 | DTC - Sub Instance | Starting real-time market data updates for: HEQ24_FUT_CME. ID: 8 2024-06-19 09:43:23.061 | DTC - Sub Instance | Requesting security definition data for: HEQ24_FUT_CME. ID: 8 2024-06-19 09:43:23.061 | Added historical Intraday data request for HEQ24_FUT_CME to the queue. 2024-06-19 09:43:23.061 | Intraday data recording state for symbol HEQ24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.061 | Triggering next historical data download in queue. 2024-06-19 09:43:23.094 | DTC - Sub Instance | Received security definition for symbol HEQ24_FUT_CME 2024-06-19 09:43:23.118 | DTC - Sub Instance | Starting real-time market data updates for: ZCN24_FUT_CME. ID: 9 2024-06-19 09:43:23.118 | DTC - Sub Instance | Requesting security definition data for: ZCN24_FUT_CME. ID: 9 2024-06-19 09:43:23.136 | DTC - Sub Instance | Received security definition for symbol ZCN24_FUT_CME 2024-06-19 09:43:23.240 | DTC - Sub Instance | Starting real-time market data updates for: 6CZ23_FUT_CME. ID: 10 2024-06-19 09:43:23.240 | DTC - Sub Instance | Requesting security definition data for: 6CZ23_FUT_CME. ID: 10 2024-06-19 09:43:23.240 | Added historical Intraday data request for 6CZ23_FUT_CME to the queue. 2024-06-19 09:43:23.240 | Intraday data recording state for symbol 6CZ23_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.240 | Triggering next historical data download in queue. 2024-06-19 09:43:23.241 | DTC - Sub Instance | Starting real-time market data updates for: PLN24_FUT_CME. ID: 11 2024-06-19 09:43:23.241 | DTC - Sub Instance | Requesting security definition data for: PLN24_FUT_CME. ID: 11 2024-06-19 09:43:23.247 | Added historical Intraday data request for ZCN24_FUT_CME to the queue. 2024-06-19 09:43:23.247 | Intraday data recording state for symbol ZCN24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.252 | Triggering next historical data download in queue. 2024-06-19 09:43:23.259 | DTC - Sub Instance | Received security definition for symbol 6CZ23_FUT_CME 2024-06-19 09:43:23.270 | DTC - Sub Instance | Received security definition for symbol PLN24_FUT_CME 2024-06-19 09:43:23.270 | DTC - Sub Instance | Starting real-time market data updates for: ZWU24_FUT_CME. ID: 12 2024-06-19 09:43:23.270 | DTC - Sub Instance | Requesting security definition data for: ZWU24_FUT_CME. ID: 12 2024-06-19 09:43:23.273 | Added historical Intraday data request for ZWU24_FUT_CME to the queue. 2024-06-19 09:43:23.273 | Intraday data recording state for symbol ZWU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.276 | Triggering next historical data download in queue. 2024-06-19 09:43:23.278 | DTC - Sub Instance | Received security definition for symbol ZWU24_FUT_CME 2024-06-19 09:43:23.296 | DTC - Sub Instance | Starting real-time market data updates for: ZSN24_FUT_CME. ID: 13 2024-06-19 09:43:23.296 | DTC - Sub Instance | Requesting security definition data for: ZSN24_FUT_CME. ID: 13 2024-06-19 09:43:23.296 | Added historical Intraday data request for ZSN24_FUT_CME to the queue. 2024-06-19 09:43:23.296 | Intraday data recording state for symbol ZSN24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.296 | Triggering next historical data download in queue. 2024-06-19 09:43:23.314 | DTC - Sub Instance | Received security definition for symbol ZSN24_FUT_CME 2024-06-19 09:43:23.359 | DTC - Sub Instance | Starting real-time market data updates for: 6AU24_FUT_CME. ID: 14 2024-06-19 09:43:23.359 | DTC - Sub Instance | Requesting security definition data for: 6AU24_FUT_CME. ID: 14 2024-06-19 09:43:23.362 | Added historical Intraday data request for 6AU24_FUT_CME to the queue. 2024-06-19 09:43:23.362 | Intraday data recording state for symbol 6AU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.362 | Triggering next historical data download in queue. 2024-06-19 09:43:23.386 | DTC - Sub Instance | Received security definition for symbol 6AU24_FUT_CME 2024-06-19 09:43:23.414 | DTC - Sub Instance | Starting real-time market data updates for: MGCQ24_FUT_CME. ID: 15 2024-06-19 09:43:23.414 | DTC - Sub Instance | Requesting security definition data for: MGCQ24_FUT_CME. ID: 15 2024-06-19 09:43:23.439 | DTC - Sub Instance | Starting real-time market data updates for: 6JU24_FUT_CME. ID: 16 2024-06-19 09:43:23.439 | DTC - Sub Instance | Requesting security definition data for: 6JU24_FUT_CME. ID: 16 2024-06-19 09:43:23.439 | Added historical Intraday data request for 6JU24_FUT_CME to the queue. 2024-06-19 09:43:23.439 | Intraday data recording state for symbol 6JU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.439 | Triggering next historical data download in queue. 2024-06-19 09:43:23.446 | DTC - Sub Instance | Received security definition for symbol MGCQ24_FUT_CME 2024-06-19 09:43:23.464 | DTC - Sub Instance | Received security definition for symbol 6JU24_FUT_CME 2024-06-19 09:43:23.472 | DTC - Sub Instance | Starting real-time market data updates for: 6CU24_FUT_CME. ID: 17 2024-06-19 09:43:23.472 | DTC - Sub Instance | Requesting security definition data for: 6CU24_FUT_CME. ID: 17 2024-06-19 09:43:23.487 | DTC - Sub Instance | Starting real-time market data updates for: SIN24_FUT_CME. ID: 18 2024-06-19 09:43:23.487 | DTC - Sub Instance | Requesting security definition data for: SIN24_FUT_CME. ID: 18 2024-06-19 09:43:23.487 | Added historical Intraday data request for SIN24_FUT_CME to the queue. 2024-06-19 09:43:23.487 | Intraday data recording state for symbol SIN24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.490 | Triggering next historical data download in queue. 2024-06-19 09:43:23.500 | DTC - Sub Instance | Received security definition for symbol 6CU24_FUT_CME 2024-06-19 09:43:23.501 | DTC - Sub Instance | Received security definition for symbol SIN24_FUT_CME 2024-06-19 09:43:23.581 | DTC - Sub Instance | Starting real-time market data updates for: 6BU24_FUT_CME. ID: 19 2024-06-19 09:43:23.581 | DTC - Sub Instance | Requesting security definition data for: 6BU24_FUT_CME. ID: 19 2024-06-19 09:43:23.581 | Added historical Intraday data request for 6BU24_FUT_CME to the queue. 2024-06-19 09:43:23.581 | Intraday data recording state for symbol 6BU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.582 | Triggering next historical data download in queue. 2024-06-19 09:43:23.606 | DTC - Sub Instance | Received security definition for symbol 6BU24_FUT_CME 2024-06-19 09:43:23.643 | DTC - Sub Instance | Starting real-time market data updates for: ZLN24_FUT_CME. ID: 20 2024-06-19 09:43:23.643 | DTC - Sub Instance | Requesting security definition data for: ZLN24_FUT_CME. ID: 20 2024-06-19 09:43:23.643 | Added historical Intraday data request for ZLN24_FUT_CME to the queue. 2024-06-19 09:43:23.643 | Intraday data recording state for symbol ZLN24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.643 | Triggering next historical data download in queue. 2024-06-19 09:43:23.655 | DTC - Sub Instance | Received security definition for symbol ZLN24_FUT_CME 2024-06-19 09:43:23.715 | DTC - Sub Instance | Starting real-time market data updates for: MCLQ24_FUT_CME. ID: 21 2024-06-19 09:43:23.715 | DTC - Sub Instance | Requesting security definition data for: MCLQ24_FUT_CME. ID: 21 2024-06-19 09:43:23.715 | Added historical Intraday data request for MCLQ24_FUT_CME to the queue. 2024-06-19 09:43:23.715 | Intraday data recording state for symbol MCLQ24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.715 | Triggering next historical data download in queue. 2024-06-19 09:43:23.741 | DTC - Sub Instance | Received security definition for symbol MCLQ24_FUT_CME 2024-06-19 09:43:23.794 | Added historical Intraday data request for MGCQ24_FUT_CME to the queue. 2024-06-19 09:43:23.794 | Intraday data recording state for symbol MGCQ24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.794 | Triggering next historical data download in queue. 2024-06-19 09:43:23.815 | Added historical Intraday data request for 6CU24_FUT_CME to the queue. 2024-06-19 09:43:23.815 | Intraday data recording state for symbol 6CU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.815 | Triggering next historical data download in queue. 2024-06-19 09:43:23.845 | Symbol settings MD5 received. Request ID: 2. 2024-06-19 09:43:23.845 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2024-06-19 09:43:23.887 | Added historical Intraday data request for PLN24_FUT_CME to the queue. 2024-06-19 09:43:23.887 | Intraday data recording state for symbol PLN24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.889 | Triggering next historical data download in queue. 2024-06-19 09:43:23.954 | DTC - Sub Instance | Starting real-time market data updates for: MESH24_FUT_CME. ID: 22 2024-06-19 09:43:23.954 | DTC - Sub Instance | Requesting security definition data for: MESH24_FUT_CME. ID: 22 2024-06-19 09:43:23.969 | DTC - Sub Instance | Starting real-time market data updates for: SIU24_FUT_CME. ID: 23 2024-06-19 09:43:23.969 | DTC - Sub Instance | Requesting security definition data for: SIU24_FUT_CME. ID: 23 2024-06-19 09:43:23.969 | Added historical Intraday data request for SIU24_FUT_CME to the queue. 2024-06-19 09:43:23.969 | Intraday data recording state for symbol SIU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:23.969 | Triggering next historical data download in queue. 2024-06-19 09:43:23.970 | DTC - Sub Instance | Received security definition for symbol MESH24_FUT_CME 2024-06-19 09:43:23.970 | DTC - Sub Instance | Received security definition for symbol SIU24_FUT_CME 2024-06-19 09:43:24.041 | DTC - Sub Instance | Starting real-time market data updates for: MESM24_FUT_CME. ID: 24 2024-06-19 09:43:24.041 | DTC - Sub Instance | Requesting security definition data for: MESM24_FUT_CME. ID: 24 2024-06-19 09:43:24.042 | Added historical Intraday data request for MESM24_FUT_CME to the queue. 2024-06-19 09:43:24.042 | Intraday data recording state for symbol MESM24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:24.042 | Triggering next historical data download in queue. 2024-06-19 09:43:24.085 | DTC - Sub Instance | Received security definition for symbol MESM24_FUT_CME 2024-06-19 09:43:24.181 | Added historical Intraday data request for ZMN24_FUT_CME to the queue. 2024-06-19 09:43:24.181 | Intraday data recording state for symbol ZMN24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:24.181 | Triggering next historical data download in queue. 2024-06-19 09:43:24.262 | DTC - Sub Instance | Starting real-time market data updates for: 6NU24_FUT_CME. ID: 25 2024-06-19 09:43:24.262 | DTC - Sub Instance | Requesting security definition data for: 6NU24_FUT_CME. ID: 25 2024-06-19 09:43:24.262 | Added historical Intraday data request for 6NU24_FUT_CME to the queue. 2024-06-19 09:43:24.262 | Intraday data recording state for symbol 6NU24_FUT_CME is set to download 'Pending'. 2024-06-19 09:43:24.268 | Triggering next historical data download in queue. 2024-06-19 09:43:24.288 | DTC - Sub Instance | Received security definition for symbol 6NU24_FUT_CME 2024-06-19 09:43:28.068 | HD Request # 33 | Downloading Intraday chart data for MESU24_FUT_CME to the file MESU24_FUT_CME.scid. Service: cme 2024-06-19 09:43:28.069 | HD Request # 33 | Download start date-time: 2024-06-19 09:43:16.000000. File last date-time: 2024-06-19 09:43:16.000000 2024-06-19 09:43:28.075 | HD Request # 33 | Using server: ds26.sierracharts.com port 10149 2024-06-19 09:43:28.075 | Socket (2) | Creating socket. 2024-06-19 09:43:28.075 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:28.075 | Socket (2) | Connecting to IP: 38.103.112.197. 2024-06-19 09:43:28.207 | HD Request # 33 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:28.207 | HD Request # 33 | Sending historical data logon request message. 2024-06-19 09:43:28.541 | HD Request # 33 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:16. Record interval: 1. Symbol: MESU24 2024-06-19 09:43:28.599 | HD Request # 33 | Decompressing data. 2024-06-19 09:43:28.658 | HD Request # 33 | Receiving Intraday data for MESU24_FUT_CME starting at 2024-06-19 09:43:16.420000 2024-06-19 09:43:28.664 | Socket (2) | CloseSocket call. 2024-06-19 09:43:28.664 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:28.677 | Historical data download thread signaled to stop. 2024-06-19 09:43:28.677 | HD Request # 33 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:16.420000. 2024-06-19 09:43:28.677 | HD Request # 33 | Received 3 Intraday data records from 2024-06-19 09:43:16.420000 to 2024-06-19 09:43:22.071000 (5.7 seconds. Delay: 6.6 seconds) and wrote 3 records for MESU24_FUT_CME 2024-06-19 09:43:28.678 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:22.071000 2024-06-19 09:43:28.683 | HD Request # 33 | Completion time: 0s. 2024-06-19 09:43:28.683 | HD Request # 33 | Intraday data download complete for MESU24_FUT_CME. Unique request ID: 33 2024-06-19 09:43:28.683 | Removing historical data download ID 33. 2024-06-19 09:43:28.683 | Real-time Intraday chart data file updates started for MESU24_FUT_CME 2024-06-19 09:43:28.684 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\MESU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:28.684 | Intraday chart data file opened for MESU24_FUT_CME 2024-06-19 09:43:28.684 | HD Request # 33 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:28.684 | 2024-06-19 09:43:28.689 | Triggering next historical data download in queue. 2024-06-19 09:43:28.690 | HD Request # 34 | Downloading Intraday chart data for M2KU24_FUT_CME to the file M2KU24_FUT_CME.scid. Service: cme 2024-06-19 09:43:28.690 | HD Request # 34 | Download start date-time: 2024-06-19 09:43:09.000000. File last date-time: 2024-06-19 09:43:09.000000 2024-06-19 09:43:28.695 | HD Request # 34 | Using server: ds28.sierracharts.com port 10150 2024-06-19 09:43:28.696 | Socket (3) | Creating socket. 2024-06-19 09:43:28.696 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:28.696 | Socket (3) | Connecting to IP: 38.103.112.187. 2024-06-19 09:43:28.727 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:28.727 | Socket (2) | Closed. 2024-06-19 09:43:28.837 | HD Request # 34 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:28.837 | HD Request # 34 | Sending historical data logon request message. 2024-06-19 09:43:28.860 | Requesting market depth updates for: 6CZ23_FUT_CME if supported. NumLevels=1400 2024-06-19 09:43:28.860 | Requesting market depth updates for: MESM24_FUT_CME if supported. NumLevels=1400 2024-06-19 09:43:28.861 | DTC - Sub Instance | Clearing market depth for 6CZ23_FUT_CME | Number times message added: 1 2024-06-19 09:43:28.861 | DTC - Sub Instance | Clearing market depth for MESM24_FUT_CME | Number times message added: 1 2024-06-19 09:43:29.169 | HD Request # 34 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:09. Record interval: 1. Symbol: M2KU24 2024-06-19 09:43:29.232 | HD Request # 34 | Decompressing data. 2024-06-19 09:43:29.294 | HD Request # 34 | Receiving Intraday data for M2KU24_FUT_CME starting at 2024-06-19 09:43:09.916000 2024-06-19 09:43:29.295 | Socket (3) | CloseSocket call. 2024-06-19 09:43:29.295 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:29.309 | Historical data download thread signaled to stop. 2024-06-19 09:43:29.309 | HD Request # 34 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:09.916000. 2024-06-19 09:43:29.309 | HD Request # 34 | Received 2 Intraday data records from 2024-06-19 09:43:09.916000 to 2024-06-19 09:43:21.500000 (11.6 seconds. Delay: 7.8 seconds) and wrote 2 records for M2KU24_FUT_CME 2024-06-19 09:43:29.309 | HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:21.500000 2024-06-19 09:43:29.309 | Added 1 Time and Sales records to Intraday data file for M2KU24_FUT_CME after download. 2024-06-19 09:43:29.309 | HD Request # 34 | Completion time: 1s. 2024-06-19 09:43:29.309 | HD Request # 34 | Intraday data download complete for M2KU24_FUT_CME. Unique request ID: 34 2024-06-19 09:43:29.309 | Removing historical data download ID 34. 2024-06-19 09:43:29.309 | Real-time Intraday chart data file updates started for M2KU24_FUT_CME 2024-06-19 09:43:29.310 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\M2KU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:29.310 | Intraday chart data file opened for M2KU24_FUT_CME 2024-06-19 09:43:29.310 | HD Request # 34 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:29.310 | 2024-06-19 09:43:29.315 | Triggering next historical data download in queue. 2024-06-19 09:43:29.321 | HD Request # 35 | Downloading Intraday chart data for LEQ24_FUT_CME to the file LEQ24_FUT_CME.scid. Service: cme 2024-06-19 09:43:29.321 | HD Request # 35 | Download start date-time: 2024-06-18 14:04:59.000000. File last date-time: 2024-06-18 14:04:59.211000 2024-06-19 09:43:29.327 | HD Request # 35 | Using server: ds32.sierracharts.com port 10149 2024-06-19 09:43:29.327 | Socket (2) | Creating socket. 2024-06-19 09:43:29.328 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:29.328 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-06-19 09:43:29.354 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:29.354 | Socket (3) | Closed. 2024-06-19 09:43:29.456 | HD Request # 35 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:29.456 | HD Request # 35 | Sending historical data logon request message. 2024-06-19 09:43:29.723 | Chart #2 has tagged chart #1 for full recalculation. Chartbook: MEStpo.Cht 2024-06-19 09:43:29.723 | Chart #2 has tagged chart #4 for full recalculation. Chartbook: MEStpo.Cht 2024-06-19 09:43:29.723 | Chart #2 has tagged chart #5 for full recalculation. Chartbook: MEStpo.Cht 2024-06-19 09:43:29.730 | Chart #2 has tagged chart #7 for full recalculation. Chartbook: Chartbook2.Cht 2024-06-19 09:43:29.767 | M2KU24_FUT_CME [CV] Daily #7 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook2.Cht 2024-06-19 09:43:29.767 | HD Request # 35 | Requesting Intraday data. Start date-time: 2024-06-18 14:04:59. Record interval: 1. Symbol: LEQ24 2024-06-19 09:43:29.823 | HD Request # 35 | Decompressing data. 2024-06-19 09:43:29.874 | HD Request # 35 | Receiving Intraday data for LEQ24_FUT_CME starting at 2024-06-18 14:04:59.211000 2024-06-19 09:43:29.874 | Socket (2) | CloseSocket call. 2024-06-19 09:43:29.874 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:29.927 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:29.927 | Socket (2) | Closed. 2024-06-19 09:43:30.435 | Historical data download thread signaled to stop. 2024-06-19 09:43:30.435 | HD Request # 35 | Timestamp of first Intraday data file record written: 2024-06-18 14:04:59.211000. 2024-06-19 09:43:30.435 | HD Request # 35 | Received 1 Intraday data record from 2024-06-18 14:04:59.211000 to 2024-06-18 14:04:59.211000 (0.0 seconds. Delay: 19.6 hours) and wrote 1 record for LEQ24_FUT_CME 2024-06-19 09:43:30.436 | HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2024-06-18 18:04:59.211000 2024-06-19 09:43:30.438 | HD Request # 35 | Completion time: 1s. 2024-06-19 09:43:30.438 | HD Request # 35 | Intraday data download complete for LEQ24_FUT_CME. Unique request ID: 35 2024-06-19 09:43:30.438 | Removing historical data download ID 35. 2024-06-19 09:43:30.438 | Real-time Intraday chart data file updates started for LEQ24_FUT_CME 2024-06-19 09:43:30.438 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\LEQ24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:30.438 | Intraday chart data file opened for LEQ24_FUT_CME 2024-06-19 09:43:30.438 | HD Request # 35 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:30.438 | 2024-06-19 09:43:30.441 | Triggering next historical data download in queue. 2024-06-19 09:43:30.441 | HD Request # 36 | Downloading Intraday chart data for 6EU24_FUT_CME to the file 6EU24_FUT_CME.scid. Service: cme 2024-06-19 09:43:30.441 | HD Request # 36 | Download start date-time: 2024-06-19 09:43:01.000000. File last date-time: 2024-06-19 09:43:01.000000 2024-06-19 09:43:30.446 | HD Request # 36 | Using server: ds27.sierracharts.com port 10150 2024-06-19 09:43:30.447 | Socket (2) | Creating socket. 2024-06-19 09:43:30.447 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:30.447 | Socket (2) | Connecting to IP: 208.185.224.131. 2024-06-19 09:43:30.485 | MESU24_FUT_CME [CV] Daily #4 | Performing a full recalculation because it has been tagged. Chartbook: MEStpo.Cht 2024-06-19 09:43:30.545 | HD Request # 36 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:30.545 | HD Request # 36 | Sending historical data logon request message. 2024-06-19 09:43:30.603 | Chart #2 has tagged chart #7 for full recalculation. Chartbook: Equities.Cht 2024-06-19 09:43:30.609 | MESU24_FUT_CME [CB] 1 Day #5 | Performing a full recalculation because it has been tagged. Chartbook: MEStpo.Cht 2024-06-19 09:43:30.814 | HD Request # 36 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:01. Record interval: 1. Symbol: 6EU24 2024-06-19 09:43:30.871 | HD Request # 36 | Decompressing data. 2024-06-19 09:43:30.910 | HD Request # 36 | Receiving Intraday data for 6EU24_FUT_CME starting at 2024-06-19 09:43:01.088000 2024-06-19 09:43:30.916 | Socket (2) | CloseSocket call. 2024-06-19 09:43:30.916 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:30.923 | Historical data download thread signaled to stop. 2024-06-19 09:43:30.923 | HD Request # 36 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:01.088000. 2024-06-19 09:43:30.923 | HD Request # 36 | Received 2 Intraday data records from 2024-06-19 09:43:01.088000 to 2024-06-19 09:43:22.746000 (21.7 seconds. Delay: 8.2 seconds) and wrote 2 records for 6EU24_FUT_CME 2024-06-19 09:43:30.924 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:22.746000 2024-06-19 09:43:30.929 | HD Request # 36 | Completion time: 0s. 2024-06-19 09:43:30.929 | HD Request # 36 | Intraday data download complete for 6EU24_FUT_CME. Unique request ID: 36 2024-06-19 09:43:30.929 | Removing historical data download ID 36. 2024-06-19 09:43:30.929 | Real-time Intraday chart data file updates started for 6EU24_FUT_CME 2024-06-19 09:43:30.930 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\6EU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:30.930 | Intraday chart data file opened for 6EU24_FUT_CME 2024-06-19 09:43:30.930 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:30.930 | 2024-06-19 09:43:30.935 | Triggering next historical data download in queue. 2024-06-19 09:43:30.942 | HD Request # 37 | Downloading Intraday chart data for HEQ24_FUT_CME to the file HEQ24_FUT_CME.scid. Service: cme 2024-06-19 09:43:30.942 | HD Request # 37 | Download start date-time: 2024-06-18 14:04:59.000000. File last date-time: 2024-06-18 14:04:59.402000 2024-06-19 09:43:30.948 | HD Request # 37 | Using server: ds26.sierracharts.com port 10149 2024-06-19 09:43:30.948 | Socket (3) | Creating socket. 2024-06-19 09:43:30.948 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:30.948 | Socket (3) | Connecting to IP: 38.103.112.197. 2024-06-19 09:43:30.961 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:30.961 | Socket (2) | Closed. 2024-06-19 09:43:31.073 | HD Request # 37 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:31.073 | HD Request # 37 | Sending historical data logon request message. 2024-06-19 09:43:31.134 | HD Request # 37 | Requesting Intraday data. Start date-time: 2024-06-18 14:04:59. Record interval: 1. Symbol: HEQ24 2024-06-19 09:43:31.162 | M2KU24_FUT_CME [CV] Daily #7 | Performing a full recalculation because it has been tagged. Chartbook: Equities.Cht 2024-06-19 09:43:31.193 | HD Request # 37 | Decompressing data. 2024-06-19 09:43:31.253 | HD Request # 37 | Receiving Intraday data for HEQ24_FUT_CME starting at 2024-06-18 14:04:59.402000 2024-06-19 09:43:31.254 | Socket (3) | CloseSocket call. 2024-06-19 09:43:31.254 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:31.311 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:31.311 | Socket (3) | Closed. 2024-06-19 09:43:31.804 | Historical data download thread signaled to stop. 2024-06-19 09:43:31.804 | HD Request # 37 | Timestamp of first Intraday data file record written: 2024-06-18 14:04:59.402000. 2024-06-19 09:43:31.805 | HD Request # 37 | Received 1 Intraday data record from 2024-06-18 14:04:59.402000 to 2024-06-18 14:04:59.402000 (0.0 seconds. Delay: 19.6 hours) and wrote 1 record for HEQ24_FUT_CME 2024-06-19 09:43:31.805 | HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2024-06-18 18:04:59.402000 2024-06-19 09:43:31.810 | HD Request # 37 | Completion time: 1s. 2024-06-19 09:43:31.810 | HD Request # 37 | Intraday data download complete for HEQ24_FUT_CME. Unique request ID: 37 2024-06-19 09:43:31.810 | Removing historical data download ID 37. 2024-06-19 09:43:31.810 | Real-time Intraday chart data file updates started for HEQ24_FUT_CME 2024-06-19 09:43:31.811 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\HEQ24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:31.811 | Intraday chart data file opened for HEQ24_FUT_CME 2024-06-19 09:43:31.811 | HD Request # 37 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:31.811 | 2024-06-19 09:43:31.811 | Triggering next historical data download in queue. 2024-06-19 09:43:31.817 | HD Request # 38 | Downloading Intraday chart data for 6CZ23_FUT_CME to the file 6CZ23_FUT_CME.scid. Service: cme 2024-06-19 09:43:31.817 | HD Request # 38 | Download start date-time: 2023-12-19 10:02:44.000000. File last date-time: 2023-12-19 10:02:44.025000 2024-06-19 09:43:31.823 | HD Request # 38 | Using server: ds28.sierracharts.com port 10150 2024-06-19 09:43:31.823 | Socket (2) | Creating socket. 2024-06-19 09:43:31.823 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:31.823 | Socket (2) | Connecting to IP: 38.103.112.187. 2024-06-19 09:43:31.957 | HD Request # 38 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:31.957 | HD Request # 38 | Sending historical data logon request message. 2024-06-19 09:43:32.026 | HD Request # 38 | Requesting Intraday data. Start date-time: 2023-12-19 10:02:44. Record interval: 1. Symbol: 6CZ23 2024-06-19 09:43:32.094 | HD Request # 38 | Decompressing data. 2024-06-19 09:43:32.154 | HD Request # 38 | Receiving Intraday data for 6CZ23_FUT_CME starting at 2023-12-19 10:02:44.025000 2024-06-19 09:43:32.160 | Socket (2) | CloseSocket call. 2024-06-19 09:43:32.160 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:32.173 | Historical data download thread signaled to stop. 2024-06-19 09:43:32.173 | HD Request # 38 | Timestamp of first Intraday data file record written: 2023-12-19 10:02:44.025000. 2024-06-19 09:43:32.173 | HD Request # 38 | Received 1 Intraday data record from 2023-12-19 10:02:44.025000 to 2023-12-19 10:02:44.025000 (0.0 seconds. Delay: 182.9 days) and wrote 1 record for 6CZ23_FUT_CME 2024-06-19 09:43:32.174 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2023-12-19 15:02:44.025000 2024-06-19 09:43:32.174 | HD Request # 38 | Completion time: 1s. 2024-06-19 09:43:32.174 | HD Request # 38 | Intraday data download complete for 6CZ23_FUT_CME. Unique request ID: 38 2024-06-19 09:43:32.174 | Removing historical data download ID 38. 2024-06-19 09:43:32.174 | Real-time Intraday chart data file updates started for 6CZ23_FUT_CME 2024-06-19 09:43:32.174 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\6CZ23_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:32.174 | Intraday chart data file opened for 6CZ23_FUT_CME 2024-06-19 09:43:32.174 | HD Request # 38 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:32.174 | 2024-06-19 09:43:32.179 | Triggering next historical data download in queue. 2024-06-19 09:43:32.179 | HD Request # 39 | Downloading Intraday chart data for ZCN24_FUT_CME to the file ZCN24_FUT_CME.scid. Service: cbot 2024-06-19 09:43:32.180 | HD Request # 39 | Download start date-time: 2024-06-18 14:19:59.000000. File last date-time: 2024-06-18 14:19:59.005000 2024-06-19 09:43:32.185 | HD Request # 39 | Using server: ds32.sierracharts.com port 10149 2024-06-19 09:43:32.185 | Socket (3) | Creating socket. 2024-06-19 09:43:32.185 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:32.185 | Socket (3) | Connecting to IP: 67.214.125.3. 2024-06-19 09:43:32.220 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:32.220 | Socket (2) | Closed. 2024-06-19 09:43:32.310 | HD Request # 39 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:32.310 | HD Request # 39 | Sending historical data logon request message. 2024-06-19 09:43:32.368 | HD Request # 39 | Requesting Intraday data. Start date-time: 2024-06-18 14:19:59. Record interval: 1. Symbol: ZCN24 2024-06-19 09:43:32.434 | HD Request # 39 | Decompressing data. 2024-06-19 09:43:32.477 | HD Request # 39 | Receiving Intraday data for ZCN24_FUT_CME starting at 2024-06-18 14:19:59.005000 2024-06-19 09:43:32.483 | Socket (3) | CloseSocket call. 2024-06-19 09:43:32.483 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:32.483 | Historical data download thread signaled to stop. 2024-06-19 09:43:32.483 | HD Request # 39 | Timestamp of first Intraday data file record written: 2024-06-18 14:19:59.005000. 2024-06-19 09:43:32.483 | HD Request # 39 | Received 1 Intraday data record from 2024-06-18 14:19:59.005000 to 2024-06-18 14:19:59.005000 (0.0 seconds. Delay: 19.4 hours) and wrote 1 record for ZCN24_FUT_CME 2024-06-19 09:43:32.484 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2024-06-18 18:19:59.005000 2024-06-19 09:43:32.484 | HD Request # 39 | Completion time: 0s. 2024-06-19 09:43:32.484 | HD Request # 39 | Intraday data download complete for ZCN24_FUT_CME. Unique request ID: 39 2024-06-19 09:43:32.484 | Removing historical data download ID 39. 2024-06-19 09:43:32.484 | Real-time Intraday chart data file updates started for ZCN24_FUT_CME 2024-06-19 09:43:32.485 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\ZCN24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:32.485 | Intraday chart data file opened for ZCN24_FUT_CME 2024-06-19 09:43:32.485 | HD Request # 39 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:32.485 | 2024-06-19 09:43:32.486 | Triggering next historical data download in queue. 2024-06-19 09:43:32.489 | HD Request # 40 | Downloading Intraday chart data for ZWU24_FUT_CME to the file ZWU24_FUT_CME.scid. Service: cbot 2024-06-19 09:43:32.490 | HD Request # 40 | Download start date-time: 2024-06-18 14:19:59.000000. File last date-time: 2024-06-18 14:19:59.552000 2024-06-19 09:43:32.495 | HD Request # 40 | Using server: ds27.sierracharts.com port 10150 2024-06-19 09:43:32.495 | Socket (2) | Creating socket. 2024-06-19 09:43:32.495 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:32.495 | Socket (2) | Connecting to IP: 208.185.224.131. 2024-06-19 09:43:32.533 | MESU24_FUT_CME [CV] Weekly #1 | Performing a full recalculation because it has been tagged. Chartbook: MEStpo.Cht 2024-06-19 09:43:32.538 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:32.538 | Socket (3) | Closed. 2024-06-19 09:43:32.599 | HD Request # 40 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:32.599 | HD Request # 40 | Sending historical data logon request message. 2024-06-19 09:43:32.616 | Chart #6 has tagged chart #7 for full recalculation. Chartbook: Tradechart.Cht 2024-06-19 09:43:32.648 | HD Request # 40 | Requesting Intraday data. Start date-time: 2024-06-18 14:19:59. Record interval: 1. Symbol: ZWU24 2024-06-19 09:43:32.698 | HD Request # 40 | Decompressing data. 2024-06-19 09:43:32.740 | HD Request # 40 | Receiving Intraday data for ZWU24_FUT_CME starting at 2024-06-18 14:19:59.552000 2024-06-19 09:43:32.741 | Socket (2) | CloseSocket call. 2024-06-19 09:43:32.741 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:32.753 | Historical data download thread signaled to stop. 2024-06-19 09:43:32.753 | HD Request # 40 | Timestamp of first Intraday data file record written: 2024-06-18 14:19:59.552000. 2024-06-19 09:43:32.753 | HD Request # 40 | Received 1 Intraday data record from 2024-06-18 14:19:59.552000 to 2024-06-18 14:19:59.552000 (0.0 seconds. Delay: 19.4 hours) and wrote 1 record for ZWU24_FUT_CME 2024-06-19 09:43:32.754 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2024-06-18 18:19:59.552000 2024-06-19 09:43:32.759 | HD Request # 40 | Completion time: 0s. 2024-06-19 09:43:32.759 | HD Request # 40 | Intraday data download complete for ZWU24_FUT_CME. Unique request ID: 40 2024-06-19 09:43:32.759 | Removing historical data download ID 40. 2024-06-19 09:43:32.759 | Real-time Intraday chart data file updates started for ZWU24_FUT_CME 2024-06-19 09:43:32.759 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\ZWU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:32.759 | Intraday chart data file opened for ZWU24_FUT_CME 2024-06-19 09:43:32.759 | HD Request # 40 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:32.759 | 2024-06-19 09:43:32.764 | Triggering next historical data download in queue. 2024-06-19 09:43:32.765 | HD Request # 41 | Downloading Intraday chart data for ZSN24_FUT_CME to the file ZSN24_FUT_CME.scid. Service: cbot 2024-06-19 09:43:32.765 | HD Request # 41 | Download start date-time: 2024-06-18 14:19:57.000000. File last date-time: 2024-06-18 14:19:57.150000 2024-06-19 09:43:32.770 | HD Request # 41 | Using server: ds26.sierracharts.com port 10149 2024-06-19 09:43:32.770 | Socket (3) | Creating socket. 2024-06-19 09:43:32.771 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:32.771 | Socket (3) | Connecting to IP: 38.103.112.197. 2024-06-19 09:43:32.785 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:32.785 | Socket (2) | Closed. 2024-06-19 09:43:32.815 | HEQ24_FUT_CME [CB] 2 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Tradechart.Cht 2024-06-19 09:43:32.901 | HD Request # 41 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:32.901 | HD Request # 41 | Sending historical data logon request message. 2024-06-19 09:43:32.964 | HD Request # 41 | Requesting Intraday data. Start date-time: 2024-06-18 14:19:57. Record interval: 1. Symbol: ZSN24 2024-06-19 09:43:33.024 | HD Request # 41 | Decompressing data. 2024-06-19 09:43:33.079 | HD Request # 41 | Receiving Intraday data for ZSN24_FUT_CME starting at 2024-06-18 14:19:57.150000 2024-06-19 09:43:33.085 | Socket (3) | CloseSocket call. 2024-06-19 09:43:33.085 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:33.098 | Historical data download thread signaled to stop. 2024-06-19 09:43:33.098 | HD Request # 41 | Timestamp of first Intraday data file record written: 2024-06-18 14:19:57.150000. 2024-06-19 09:43:33.098 | HD Request # 41 | Received 1 Intraday data record from 2024-06-18 14:19:57.150000 to 2024-06-18 14:19:57.150000 (0.0 seconds. Delay: 19.4 hours) and wrote 1 record for ZSN24_FUT_CME 2024-06-19 09:43:33.098 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2024-06-18 18:19:57.150000 2024-06-19 09:43:33.098 | HD Request # 41 | Completion time: 1s. 2024-06-19 09:43:33.098 | HD Request # 41 | Intraday data download complete for ZSN24_FUT_CME. Unique request ID: 41 2024-06-19 09:43:33.098 | Removing historical data download ID 41. 2024-06-19 09:43:33.098 | Real-time Intraday chart data file updates started for ZSN24_FUT_CME 2024-06-19 09:43:33.098 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\ZSN24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:33.098 | Intraday chart data file opened for ZSN24_FUT_CME 2024-06-19 09:43:33.098 | HD Request # 41 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:33.098 | 2024-06-19 09:43:33.103 | Triggering next historical data download in queue. 2024-06-19 09:43:33.110 | HD Request # 42 | Downloading Intraday chart data for 6AU24_FUT_CME to the file 6AU24_FUT_CME.scid. Service: cme 2024-06-19 09:43:33.110 | HD Request # 42 | Download start date-time: 2024-06-19 09:42:57.000000. File last date-time: 2024-06-19 09:42:57.000000 2024-06-19 09:43:33.116 | HD Request # 42 | Using server: ds28.sierracharts.com port 10150 2024-06-19 09:43:33.116 | Socket (2) | Creating socket. 2024-06-19 09:43:33.116 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:33.116 | Socket (2) | Connecting to IP: 38.103.112.187. 2024-06-19 09:43:33.144 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:33.144 | Socket (3) | Closed. 2024-06-19 09:43:33.246 | HD Request # 42 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:33.246 | HD Request # 42 | Sending historical data logon request message. 2024-06-19 09:43:33.314 | HD Request # 42 | Requesting Intraday data. Start date-time: 2024-06-19 09:42:57. Record interval: 1. Symbol: 6AU24 2024-06-19 09:43:33.373 | HD Request # 42 | Decompressing data. 2024-06-19 09:43:33.430 | HD Request # 42 | Receiving Intraday data for 6AU24_FUT_CME starting at 2024-06-19 09:42:57.557000 2024-06-19 09:43:33.436 | Socket (2) | CloseSocket call. 2024-06-19 09:43:33.436 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:33.443 | Historical data download thread signaled to stop. 2024-06-19 09:43:33.443 | HD Request # 42 | Timestamp of first Intraday data file record written: 2024-06-19 09:42:57.557000. 2024-06-19 09:43:33.443 | HD Request # 42 | Received 1 Intraday data record from 2024-06-19 09:42:57.557000 to 2024-06-19 09:42:57.557000 (0.0 seconds. Delay: 35.9 seconds) and wrote 1 record for 6AU24_FUT_CME 2024-06-19 09:43:33.444 | HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:42:57.557000 2024-06-19 09:43:33.449 | HD Request # 42 | Completion time: 0s. 2024-06-19 09:43:33.449 | HD Request # 42 | Intraday data download complete for 6AU24_FUT_CME. Unique request ID: 42 2024-06-19 09:43:33.449 | Removing historical data download ID 42. 2024-06-19 09:43:33.449 | Real-time Intraday chart data file updates started for 6AU24_FUT_CME 2024-06-19 09:43:33.450 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\6AU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:33.450 | Intraday chart data file opened for 6AU24_FUT_CME 2024-06-19 09:43:33.450 | HD Request # 42 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:33.450 | 2024-06-19 09:43:33.452 | Triggering next historical data download in queue. 2024-06-19 09:43:33.455 | HD Request # 43 | Downloading Intraday chart data for 6JU24_FUT_CME to the file 6JU24_FUT_CME.scid. Service: cme 2024-06-19 09:43:33.456 | HD Request # 43 | Download start date-time: 2024-06-19 09:42:58.000000. File last date-time: 2024-06-19 09:42:58.000000 2024-06-19 09:43:33.461 | HD Request # 43 | Using server: ds32.sierracharts.com port 10149 2024-06-19 09:43:33.461 | Socket (3) | Creating socket. 2024-06-19 09:43:33.461 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:33.461 | Socket (3) | Connecting to IP: 67.214.125.3. 2024-06-19 09:43:33.494 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:33.494 | Socket (2) | Closed. 2024-06-19 09:43:33.580 | HD Request # 43 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:33.580 | HD Request # 43 | Sending historical data logon request message. 2024-06-19 09:43:33.636 | HD Request # 43 | Requesting Intraday data. Start date-time: 2024-06-19 09:42:58. Record interval: 1. Symbol: 6JU24 2024-06-19 09:43:33.693 | HD Request # 43 | Decompressing data. 2024-06-19 09:43:33.741 | HD Request # 43 | Receiving Intraday data for 6JU24_FUT_CME starting at 2024-06-19 09:42:58.028000 2024-06-19 09:43:33.744 | Socket (3) | CloseSocket call. 2024-06-19 09:43:33.744 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:33.760 | Historical data download thread signaled to stop. 2024-06-19 09:43:33.760 | HD Request # 43 | Timestamp of first Intraday data file record written: 2024-06-19 09:42:58.028000. 2024-06-19 09:43:33.760 | HD Request # 43 | Received 2 Intraday data records from 2024-06-19 09:42:58.028000 to 2024-06-19 09:43:22.747000 (24.7 seconds. Delay: 11.0 seconds) and wrote 2 records for 6JU24_FUT_CME 2024-06-19 09:43:33.761 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:22.747000 2024-06-19 09:43:33.761 | HD Request # 43 | Completion time: 0s. 2024-06-19 09:43:33.761 | HD Request # 43 | Intraday data download complete for 6JU24_FUT_CME. Unique request ID: 43 2024-06-19 09:43:33.761 | Removing historical data download ID 43. 2024-06-19 09:43:33.761 | Real-time Intraday chart data file updates started for 6JU24_FUT_CME 2024-06-19 09:43:33.762 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\6JU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:33.762 | Intraday chart data file opened for 6JU24_FUT_CME 2024-06-19 09:43:33.762 | HD Request # 43 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:33.762 | 2024-06-19 09:43:33.767 | Triggering next historical data download in queue. 2024-06-19 09:43:33.767 | HD Request # 44 | Downloading Intraday chart data for SIN24_FUT_CME to the file SIN24_FUT_CME.scid. Service: comex 2024-06-19 09:43:33.768 | HD Request # 44 | Download start date-time: 2024-06-19 09:43:16.000000. File last date-time: 2024-06-19 09:43:16.000000 2024-06-19 09:43:33.774 | HD Request # 44 | Using server: ds27.sierracharts.com port 10150 2024-06-19 09:43:33.774 | Socket (2) | Creating socket. 2024-06-19 09:43:33.774 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:33.774 | Socket (2) | Connecting to IP: 208.185.224.131. 2024-06-19 09:43:33.801 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:33.801 | Socket (3) | Closed. 2024-06-19 09:43:33.896 | HD Request # 44 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:33.896 | HD Request # 44 | Sending historical data logon request message. 2024-06-19 09:43:33.943 | HD Request # 44 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:16. Record interval: 1. Symbol: SIN24 2024-06-19 09:43:33.995 | HD Request # 44 | Decompressing data. 2024-06-19 09:43:34.041 | HD Request # 44 | Receiving Intraday data for SIN24_FUT_CME starting at 2024-06-19 09:43:16.073000 2024-06-19 09:43:34.047 | Socket (2) | CloseSocket call. 2024-06-19 09:43:34.047 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:34.093 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:34.093 | Socket (2) | Closed. 2024-06-19 09:43:34.146 | Historical data download thread signaled to stop. 2024-06-19 09:43:34.146 | HD Request # 44 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:16.073000. 2024-06-19 09:43:34.146 | HD Request # 44 | Received 3 Intraday data records from 2024-06-19 09:43:16.073000 to 2024-06-19 09:43:27.073000 (11.0 seconds. Delay: 7.1 seconds) and wrote 3 records for SIN24_FUT_CME 2024-06-19 09:43:34.147 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:27.073000 2024-06-19 09:43:34.147 | HD Request # 44 | Completion time: 1s. 2024-06-19 09:43:34.147 | HD Request # 44 | Intraday data download complete for SIN24_FUT_CME. Unique request ID: 44 2024-06-19 09:43:34.147 | Removing historical data download ID 44. 2024-06-19 09:43:34.147 | Real-time Intraday chart data file updates started for SIN24_FUT_CME 2024-06-19 09:43:34.147 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\SIN24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:34.147 | Intraday chart data file opened for SIN24_FUT_CME 2024-06-19 09:43:34.147 | HD Request # 44 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:34.147 | 2024-06-19 09:43:34.152 | Triggering next historical data download in queue. 2024-06-19 09:43:34.159 | HD Request # 45 | Downloading Intraday chart data for 6BU24_FUT_CME to the file 6BU24_FUT_CME.scid. Service: cme 2024-06-19 09:43:34.160 | HD Request # 45 | Download start date-time: 2024-06-19 09:43:03.000000. File last date-time: 2024-06-19 09:43:03.000000 2024-06-19 09:43:34.166 | HD Request # 45 | Using server: ds26.sierracharts.com port 10149 2024-06-19 09:43:34.166 | Socket (2) | Creating socket. 2024-06-19 09:43:34.166 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:34.166 | Socket (2) | Connecting to IP: 38.103.112.197. 2024-06-19 09:43:34.292 | HD Request # 45 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:34.292 | HD Request # 45 | Sending historical data logon request message. 2024-06-19 09:43:34.357 | HD Request # 45 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:03. Record interval: 1. Symbol: 6BU24 2024-06-19 09:43:34.421 | HD Request # 45 | Decompressing data. 2024-06-19 09:43:34.477 | HD Request # 45 | Receiving Intraday data for 6BU24_FUT_CME starting at 2024-06-19 09:43:03.833000 2024-06-19 09:43:34.484 | Socket (2) | CloseSocket call. 2024-06-19 09:43:34.484 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:34.511 | Historical data download thread signaled to stop. 2024-06-19 09:43:34.511 | HD Request # 45 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:03.833000. 2024-06-19 09:43:34.511 | HD Request # 45 | Received 3 Intraday data records from 2024-06-19 09:43:03.833000 to 2024-06-19 09:43:30.368000 (26.5 seconds. Delay: 4.1 seconds) and wrote 3 records for 6BU24_FUT_CME 2024-06-19 09:43:34.513 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:30.368000 2024-06-19 09:43:34.513 | HD Request # 45 | Completion time: 0s. 2024-06-19 09:43:34.513 | HD Request # 45 | Intraday data download complete for 6BU24_FUT_CME. Unique request ID: 45 2024-06-19 09:43:34.513 | Removing historical data download ID 45. 2024-06-19 09:43:34.513 | Real-time Intraday chart data file updates started for 6BU24_FUT_CME 2024-06-19 09:43:34.513 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\6BU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:34.513 | Intraday chart data file opened for 6BU24_FUT_CME 2024-06-19 09:43:34.513 | HD Request # 45 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:34.513 | 2024-06-19 09:43:34.518 | Triggering next historical data download in queue. 2024-06-19 09:43:34.529 | HD Request # 46 | Downloading Intraday chart data for ZLN24_FUT_CME to the file ZLN24_FUT_CME.scid. Service: cbot 2024-06-19 09:43:34.530 | HD Request # 46 | Download start date-time: 2024-06-18 14:19:57.000000. File last date-time: 2024-06-18 14:19:57.849000 2024-06-19 09:43:34.538 | HD Request # 46 | Using server: ds28.sierracharts.com port 10150 2024-06-19 09:43:34.538 | Socket (3) | Creating socket. 2024-06-19 09:43:34.539 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:34.539 | Socket (3) | Connecting to IP: 38.103.112.187. 2024-06-19 09:43:34.541 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:34.542 | Socket (2) | Closed. 2024-06-19 09:43:34.682 | HD Request # 46 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:34.682 | HD Request # 46 | Sending historical data logon request message. 2024-06-19 09:43:34.747 | HD Request # 46 | Requesting Intraday data. Start date-time: 2024-06-18 14:19:57. Record interval: 1. Symbol: ZLN24 2024-06-19 09:43:34.805 | HD Request # 46 | Decompressing data. 2024-06-19 09:43:34.867 | HD Request # 46 | Receiving Intraday data for ZLN24_FUT_CME starting at 2024-06-18 14:19:57.849000 2024-06-19 09:43:34.879 | Socket (3) | CloseSocket call. 2024-06-19 09:43:34.879 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:34.901 | Historical data download thread signaled to stop. 2024-06-19 09:43:34.901 | HD Request # 46 | Timestamp of first Intraday data file record written: 2024-06-18 14:19:57.849000. 2024-06-19 09:43:34.901 | HD Request # 46 | Received 1 Intraday data record from 2024-06-18 14:19:57.849000 to 2024-06-18 14:19:57.849000 (0.0 seconds. Delay: 19.4 hours) and wrote 1 record for ZLN24_FUT_CME 2024-06-19 09:43:34.902 | HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2024-06-18 18:19:57.849000 2024-06-19 09:43:34.907 | HD Request # 46 | Completion time: 0s. 2024-06-19 09:43:34.907 | HD Request # 46 | Intraday data download complete for ZLN24_FUT_CME. Unique request ID: 46 2024-06-19 09:43:34.907 | Removing historical data download ID 46. 2024-06-19 09:43:34.907 | Real-time Intraday chart data file updates started for ZLN24_FUT_CME 2024-06-19 09:43:34.908 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\ZLN24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:34.908 | Intraday chart data file opened for ZLN24_FUT_CME 2024-06-19 09:43:34.908 | HD Request # 46 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:34.908 | 2024-06-19 09:43:34.914 | Triggering next historical data download in queue. 2024-06-19 09:43:34.921 | HD Request # 47 | Downloading Intraday chart data for MCLQ24_FUT_CME to the file MCLQ24_FUT_CME.scid. Service: nymex 2024-06-19 09:43:34.922 | HD Request # 47 | Download start date-time: 2024-06-19 09:43:14.000000. File last date-time: 2024-06-19 09:43:14.000000 2024-06-19 09:43:34.928 | HD Request # 47 | Using server: ds32.sierracharts.com port 10149 2024-06-19 09:43:34.928 | Socket (2) | Creating socket. 2024-06-19 09:43:34.928 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:34.928 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-06-19 09:43:34.936 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:34.936 | Socket (3) | Closed. 2024-06-19 09:43:35.055 | HD Request # 47 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:35.055 | HD Request # 47 | Sending historical data logon request message. 2024-06-19 09:43:35.074 | Chart #2 has tagged chart #1 for full recalculation. Chartbook: Tradechart.Cht 2024-06-19 09:43:35.108 | HD Request # 47 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:14. Record interval: 1. Symbol: MCLQ24 2024-06-19 09:43:35.167 | HD Request # 47 | Decompressing data. 2024-06-19 09:43:35.222 | HD Request # 47 | Receiving Intraday data for MCLQ24_FUT_CME starting at 2024-06-19 09:43:14.691000 2024-06-19 09:43:35.229 | Socket (2) | CloseSocket call. 2024-06-19 09:43:35.229 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:35.263 | Historical data download thread signaled to stop. 2024-06-19 09:43:35.263 | HD Request # 47 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:14.691000. 2024-06-19 09:43:35.263 | HD Request # 47 | Received 2 Intraday data records from 2024-06-19 09:43:14.691000 to 2024-06-19 09:43:18.899000 (4.2 seconds. Delay: 16.4 seconds) and wrote 2 records for MCLQ24_FUT_CME 2024-06-19 09:43:35.264 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:18.899000 2024-06-19 09:43:35.264 | HD Request # 47 | Completion time: 1s. 2024-06-19 09:43:35.264 | HD Request # 47 | Intraday data download complete for MCLQ24_FUT_CME. Unique request ID: 47 2024-06-19 09:43:35.264 | Removing historical data download ID 47. 2024-06-19 09:43:35.264 | Real-time Intraday chart data file updates started for MCLQ24_FUT_CME 2024-06-19 09:43:35.265 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\MCLQ24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:35.265 | Intraday chart data file opened for MCLQ24_FUT_CME 2024-06-19 09:43:35.265 | HD Request # 47 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:35.265 | 2024-06-19 09:43:35.270 | Triggering next historical data download in queue. 2024-06-19 09:43:35.282 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:35.282 | Socket (2) | Closed. 2024-06-19 09:43:35.284 | HD Request # 48 | Downloading Intraday chart data for MGCQ24_FUT_CME to the file MGCQ24_FUT_CME.scid. Service: comex 2024-06-19 09:43:35.284 | HD Request # 48 | Download start date-time: 2024-06-19 09:43:12.000000. File last date-time: 2024-06-19 09:43:12.000000 2024-06-19 09:43:35.296 | HD Request # 48 | Using server: ds27.sierracharts.com port 10150 2024-06-19 09:43:35.296 | Socket (2) | Creating socket. 2024-06-19 09:43:35.297 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:35.297 | Socket (2) | Connecting to IP: 208.185.224.131. 2024-06-19 09:43:35.419 | HD Request # 48 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:35.419 | HD Request # 48 | Sending historical data logon request message. 2024-06-19 09:43:35.472 | HD Request # 48 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:12. Record interval: 1. Symbol: MGCQ24 2024-06-19 09:43:35.529 | HD Request # 48 | Decompressing data. 2024-06-19 09:43:35.575 | HD Request # 48 | Receiving Intraday data for MGCQ24_FUT_CME starting at 2024-06-19 09:43:12.228000 2024-06-19 09:43:35.582 | Socket (2) | CloseSocket call. 2024-06-19 09:43:35.582 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:35.597 | Historical data download thread signaled to stop. 2024-06-19 09:43:35.598 | HD Request # 48 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:12.228000. 2024-06-19 09:43:35.598 | HD Request # 48 | Received 8 Intraday data records from 2024-06-19 09:43:12.228000 to 2024-06-19 09:43:34.302000 (22.1 seconds. Delay: 1.3 seconds) and wrote 8 records for MGCQ24_FUT_CME 2024-06-19 09:43:35.598 | HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:34.302000 2024-06-19 09:43:35.598 | HD Request # 48 | Completion time: 0s. 2024-06-19 09:43:35.598 | HD Request # 48 | Intraday data download complete for MGCQ24_FUT_CME. Unique request ID: 48 2024-06-19 09:43:35.598 | Removing historical data download ID 48. 2024-06-19 09:43:35.598 | Real-time Intraday chart data file updates started for MGCQ24_FUT_CME 2024-06-19 09:43:35.598 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\MGCQ24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:35.598 | Intraday chart data file opened for MGCQ24_FUT_CME 2024-06-19 09:43:35.598 | HD Request # 48 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:35.598 | 2024-06-19 09:43:35.601 | Triggering next historical data download in queue. 2024-06-19 09:43:35.611 | HD Request # 49 | Downloading Intraday chart data for 6CU24_FUT_CME to the file 6CU24_FUT_CME.scid. Service: cme 2024-06-19 09:43:35.611 | HD Request # 49 | Download start date-time: 2024-06-19 09:43:09.000000. File last date-time: 2024-06-19 09:43:09.000000 2024-06-19 09:43:35.620 | HD Request # 49 | Using server: ds26.sierracharts.com port 10149 2024-06-19 09:43:35.621 | Socket (3) | Creating socket. 2024-06-19 09:43:35.621 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:35.621 | Socket (3) | Connecting to IP: 38.103.112.197. 2024-06-19 09:43:35.628 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:35.628 | Socket (2) | Closed. 2024-06-19 09:43:35.758 | MESU24_FUT_CME [CB] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Tradechart.Cht 2024-06-19 09:43:35.762 | HD Request # 49 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:35.762 | HD Request # 49 | Sending historical data logon request message. 2024-06-19 09:43:35.827 | HD Request # 49 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:09. Record interval: 1. Symbol: 6CU24 2024-06-19 09:43:35.898 | HD Request # 49 | Decompressing data. 2024-06-19 09:43:35.949 | HD Request # 49 | Receiving Intraday data for 6CU24_FUT_CME starting at 2024-06-19 09:43:09.697000 2024-06-19 09:43:35.955 | Socket (3) | CloseSocket call. 2024-06-19 09:43:35.955 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:35.962 | Historical data download thread signaled to stop. 2024-06-19 09:43:35.962 | HD Request # 49 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:09.697000. 2024-06-19 09:43:35.963 | HD Request # 49 | Received 2 Intraday data records from 2024-06-19 09:43:09.697000 to 2024-06-19 09:43:28.184000 (18.5 seconds. Delay: 7.8 seconds) and wrote 2 records for 6CU24_FUT_CME 2024-06-19 09:43:35.963 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:28.184000 2024-06-19 09:43:35.963 | HD Request # 49 | Completion time: 0s. 2024-06-19 09:43:35.963 | HD Request # 49 | Intraday data download complete for 6CU24_FUT_CME. Unique request ID: 49 2024-06-19 09:43:35.963 | Removing historical data download ID 49. 2024-06-19 09:43:35.963 | Real-time Intraday chart data file updates started for 6CU24_FUT_CME 2024-06-19 09:43:35.963 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\6CU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:35.963 | Intraday chart data file opened for 6CU24_FUT_CME 2024-06-19 09:43:35.963 | HD Request # 49 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:35.963 | 2024-06-19 09:43:35.969 | Triggering next historical data download in queue. 2024-06-19 09:43:35.975 | HD Request # 50 | Downloading Intraday chart data for PLN24_FUT_CME to the file PLN24_FUT_CME.scid. Service: nymex 2024-06-19 09:43:35.976 | HD Request # 50 | Download start date-time: 2024-06-19 09:43:10.000000. File last date-time: 2024-06-19 09:43:10.000000 2024-06-19 09:43:35.982 | HD Request # 50 | Using server: ds28.sierracharts.com port 10150 2024-06-19 09:43:35.982 | Socket (2) | Creating socket. 2024-06-19 09:43:35.982 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:35.982 | Socket (2) | Connecting to IP: 38.103.112.187. 2024-06-19 09:43:36.013 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:36.014 | Socket (3) | Closed. 2024-06-19 09:43:36.108 | HD Request # 50 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:36.108 | HD Request # 50 | Sending historical data logon request message. 2024-06-19 09:43:36.171 | HD Request # 50 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:10. Record interval: 1. Symbol: PLN24 2024-06-19 09:43:36.204 | DTC - Sub Instance | Starting real-time market data updates for: ZLZ24_FUT_CME. ID: 26 2024-06-19 09:43:36.204 | DTC - Sub Instance | Requesting security definition data for: ZLZ24_FUT_CME. ID: 26 2024-06-19 09:43:36.235 | HD Request # 50 | Decompressing data. 2024-06-19 09:43:36.236 | DTC - Sub Instance | Received security definition for symbol ZLZ24_FUT_CME 2024-06-19 09:43:36.285 | HD Request # 50 | Receiving Intraday data for PLN24_FUT_CME starting at 2024-06-19 09:43:10.074000 2024-06-19 09:43:36.289 | Socket (2) | CloseSocket call. 2024-06-19 09:43:36.289 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:36.304 | Historical data download thread signaled to stop. 2024-06-19 09:43:36.304 | HD Request # 50 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:10.074000. 2024-06-19 09:43:36.304 | HD Request # 50 | Received 2 Intraday data records from 2024-06-19 09:43:10.074000 to 2024-06-19 09:43:23.088000 (13.0 seconds. Delay: 13.2 seconds) and wrote 2 records for PLN24_FUT_CME 2024-06-19 09:43:36.305 | HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:23.088000 2024-06-19 09:43:36.305 | HD Request # 50 | Completion time: 1s. 2024-06-19 09:43:36.305 | HD Request # 50 | Intraday data download complete for PLN24_FUT_CME. Unique request ID: 50 2024-06-19 09:43:36.305 | Removing historical data download ID 50. 2024-06-19 09:43:36.305 | Real-time Intraday chart data file updates started for PLN24_FUT_CME 2024-06-19 09:43:36.306 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\PLN24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:36.306 | Intraday chart data file opened for PLN24_FUT_CME 2024-06-19 09:43:36.306 | HD Request # 50 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:36.306 | 2024-06-19 09:43:36.311 | Triggering next historical data download in queue. 2024-06-19 09:43:36.317 | HD Request # 51 | Downloading Intraday chart data for SIU24_FUT_CME to the file SIU24_FUT_CME.scid. Service: comex 2024-06-19 09:43:36.317 | HD Request # 51 | Download start date-time: 2024-06-19 09:42:55.000000. File last date-time: 2024-06-19 09:42:55.000000 2024-06-19 09:43:36.323 | HD Request # 51 | Using server: ds32.sierracharts.com port 10149 2024-06-19 09:43:36.324 | Socket (3) | Creating socket. 2024-06-19 09:43:36.324 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:36.324 | Socket (3) | Connecting to IP: 67.214.125.3. 2024-06-19 09:43:36.346 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:36.346 | Socket (2) | Closed. 2024-06-19 09:43:36.448 | HD Request # 51 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:36.448 | HD Request # 51 | Sending historical data logon request message. 2024-06-19 09:43:36.505 | HD Request # 51 | Requesting Intraday data. Start date-time: 2024-06-19 09:42:55. Record interval: 1. Symbol: SIU24 2024-06-19 09:43:36.565 | HD Request # 51 | Decompressing data. 2024-06-19 09:43:36.611 | HD Request # 51 | Receiving Intraday data for SIU24_FUT_CME starting at 2024-06-19 09:42:55.954000 2024-06-19 09:43:36.617 | Socket (3) | CloseSocket call. 2024-06-19 09:43:36.617 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:36.630 | Historical data download thread signaled to stop. 2024-06-19 09:43:36.630 | HD Request # 51 | Timestamp of first Intraday data file record written: 2024-06-19 09:42:55.954000. 2024-06-19 09:43:36.630 | HD Request # 51 | Received 2 Intraday data records from 2024-06-19 09:42:55.954000 to 2024-06-19 09:43:31.172000 (35.2 seconds. Delay: 5.5 seconds) and wrote 2 records for SIU24_FUT_CME 2024-06-19 09:43:36.631 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:31.172000 2024-06-19 09:43:36.631 | HD Request # 51 | Completion time: 0s. 2024-06-19 09:43:36.631 | HD Request # 51 | Intraday data download complete for SIU24_FUT_CME. Unique request ID: 51 2024-06-19 09:43:36.631 | Removing historical data download ID 51. 2024-06-19 09:43:36.631 | Real-time Intraday chart data file updates started for SIU24_FUT_CME 2024-06-19 09:43:36.631 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\SIU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:36.631 | Intraday chart data file opened for SIU24_FUT_CME 2024-06-19 09:43:36.631 | HD Request # 51 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:36.631 | 2024-06-19 09:43:36.636 | Triggering next historical data download in queue. 2024-06-19 09:43:36.636 | HD Request # 52 | Downloading Intraday chart data for MESM24_FUT_CME to the file MESM24_FUT_CME.scid. Service: cme 2024-06-19 09:43:36.637 | HD Request # 52 | Download start date-time: 2024-06-19 09:43:01.000000. File last date-time: 2024-06-19 09:43:01.000000 2024-06-19 09:43:36.642 | HD Request # 52 | Using server: ds27.sierracharts.com port 10150 2024-06-19 09:43:36.642 | Socket (2) | Creating socket. 2024-06-19 09:43:36.642 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:36.642 | Socket (2) | Connecting to IP: 208.185.224.131. 2024-06-19 09:43:36.670 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:36.670 | Socket (3) | Closed. 2024-06-19 09:43:36.754 | HD Request # 52 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:36.754 | HD Request # 52 | Sending historical data logon request message. 2024-06-19 09:43:36.811 | HD Request # 52 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:01. Record interval: 1. Symbol: MESM24 2024-06-19 09:43:36.880 | HD Request # 52 | Decompressing data. 2024-06-19 09:43:36.906 | HD Request # 52 | Receiving Intraday data for MESM24_FUT_CME starting at 2024-06-19 09:43:01.088000 2024-06-19 09:43:36.927 | Socket (2) | CloseSocket call. 2024-06-19 09:43:36.928 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:36.973 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:36.973 | Socket (2) | Closed. 2024-06-19 09:43:38.082 | Historical data download thread signaled to stop. 2024-06-19 09:43:38.082 | HD Request # 52 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:01.088000. 2024-06-19 09:43:38.082 | HD Request # 52 | Received 4 Intraday data records from 2024-06-19 09:43:01.088000 to 2024-06-19 09:43:31.431000 (30.3 seconds. Delay: 6.7 seconds) and wrote 4 records for MESM24_FUT_CME 2024-06-19 09:43:38.083 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:31.431000 2024-06-19 09:43:38.083 | HD Request # 52 | Completion time: 2s. 2024-06-19 09:43:38.083 | HD Request # 52 | Intraday data download complete for MESM24_FUT_CME. Unique request ID: 52 2024-06-19 09:43:38.083 | Removing historical data download ID 52. 2024-06-19 09:43:38.083 | Real-time Intraday chart data file updates started for MESM24_FUT_CME 2024-06-19 09:43:38.083 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\MESM24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:38.083 | Intraday chart data file opened for MESM24_FUT_CME 2024-06-19 09:43:38.083 | HD Request # 52 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:38.083 | 2024-06-19 09:43:38.085 | Triggering next historical data download in queue. 2024-06-19 09:43:38.136 | HD Request # 53 | Downloading Intraday chart data for ZMN24_FUT_CME to the file ZMN24_FUT_CME.scid. Service: cbot 2024-06-19 09:43:38.136 | HD Request # 53 | Download start date-time: 2024-06-18 14:19:58.000000. File last date-time: 2024-06-18 14:19:58.772000 2024-06-19 09:43:38.142 | HD Request # 53 | Using server: ds26.sierracharts.com port 10149 2024-06-19 09:43:38.142 | Socket (2) | Creating socket. 2024-06-19 09:43:38.142 | Socket (2) | New receive buffer size: 0 2024-06-19 09:43:38.142 | Socket (2) | Connecting to IP: 38.103.112.197. 2024-06-19 09:43:38.284 | HD Request # 53 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:38.284 | HD Request # 53 | Sending historical data logon request message. 2024-06-19 09:43:38.344 | HD Request # 53 | Requesting Intraday data. Start date-time: 2024-06-18 14:19:58. Record interval: 1. Symbol: ZMN24 2024-06-19 09:43:38.412 | HD Request # 53 | Decompressing data. 2024-06-19 09:43:38.432 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: Chartbook2.Cht 2024-06-19 09:43:38.432 | Chart #3 has tagged chart #6 for full recalculation. Chartbook: Chartbook2.Cht 2024-06-19 09:43:38.461 | HD Request # 53 | Receiving Intraday data for ZMN24_FUT_CME starting at 2024-06-18 14:19:58.772000 2024-06-19 09:43:38.464 | Socket (2) | CloseSocket call. 2024-06-19 09:43:38.464 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:38.478 | Historical data download thread signaled to stop. 2024-06-19 09:43:38.478 | HD Request # 53 | Timestamp of first Intraday data file record written: 2024-06-18 14:19:58.772000. 2024-06-19 09:43:38.479 | HD Request # 53 | Received 1 Intraday data record from 2024-06-18 14:19:58.772000 to 2024-06-18 14:19:58.772000 (0.0 seconds. Delay: 19.4 hours) and wrote 1 record for ZMN24_FUT_CME 2024-06-19 09:43:38.479 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2024-06-18 18:19:58.772000 2024-06-19 09:43:38.479 | HD Request # 53 | Completion time: 0s. 2024-06-19 09:43:38.479 | HD Request # 53 | Intraday data download complete for ZMN24_FUT_CME. Unique request ID: 53 2024-06-19 09:43:38.479 | Removing historical data download ID 53. 2024-06-19 09:43:38.479 | Real-time Intraday chart data file updates started for ZMN24_FUT_CME 2024-06-19 09:43:38.480 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\ZMN24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:38.480 | Intraday chart data file opened for ZMN24_FUT_CME 2024-06-19 09:43:38.480 | HD Request # 53 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:38.480 | 2024-06-19 09:43:38.485 | Triggering next historical data download in queue. 2024-06-19 09:43:38.485 | HD Request # 54 | Downloading Intraday chart data for 6NU24_FUT_CME to the file 6NU24_FUT_CME.scid. Service: cme 2024-06-19 09:43:38.486 | HD Request # 54 | Download start date-time: 2024-06-19 09:43:16.000000. File last date-time: 2024-06-19 09:43:16.000000 2024-06-19 09:43:38.492 | HD Request # 54 | Using server: ds28.sierracharts.com port 10150 2024-06-19 09:43:38.492 | Socket (3) | Creating socket. 2024-06-19 09:43:38.492 | Socket (3) | New receive buffer size: 0 2024-06-19 09:43:38.492 | Socket (3) | Connecting to IP: 38.103.112.187. 2024-06-19 09:43:38.521 | Socket (2) | Socket gracefully closed by remote side. 2024-06-19 09:43:38.521 | Socket (2) | Closed. 2024-06-19 09:43:38.622 | HD Request # 54 | Setting DTC encoding to Binary VLS 2024-06-19 09:43:38.622 | HD Request # 54 | Sending historical data logon request message. 2024-06-19 09:43:38.638 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: Equities.Cht 2024-06-19 09:43:38.638 | Chart #3 has tagged chart #6 for full recalculation. Chartbook: Equities.Cht 2024-06-19 09:43:38.646 | MCLQ24_FUT_CME [CV] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook2.Cht 2024-06-19 09:43:38.682 | HD Request # 54 | Requesting Intraday data. Start date-time: 2024-06-19 09:43:16. Record interval: 1. Symbol: 6NU24 2024-06-19 09:43:38.742 | HD Request # 54 | Decompressing data. 2024-06-19 09:43:38.801 | MCLQ24_FUT_CME [CBV] Daily #1 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook2.Cht 2024-06-19 09:43:38.802 | HD Request # 54 | Receiving Intraday data for 6NU24_FUT_CME starting at 2024-06-19 09:43:16.230000 2024-06-19 09:43:38.808 | Socket (3) | CloseSocket call. 2024-06-19 09:43:38.808 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-06-19 09:43:38.867 | Socket (3) | Socket gracefully closed by remote side. 2024-06-19 09:43:38.867 | Socket (3) | Closed. 2024-06-19 09:43:39.010 | Historical data download thread signaled to stop. 2024-06-19 09:43:39.010 | HD Request # 54 | Timestamp of first Intraday data file record written: 2024-06-19 09:43:16.230000. 2024-06-19 09:43:39.011 | HD Request # 54 | Received 1 Intraday data record from 2024-06-19 09:43:16.230000 to 2024-06-19 09:43:16.230000 (0.0 seconds. Delay: 22.8 seconds) and wrote 1 record for 6NU24_FUT_CME 2024-06-19 09:43:39.011 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2024-06-19 13:43:16.230000 2024-06-19 09:43:39.011 | HD Request # 54 | Completion time: 1s. 2024-06-19 09:43:39.011 | HD Request # 54 | Intraday data download complete for 6NU24_FUT_CME. Unique request ID: 54 2024-06-19 09:43:39.011 | Removing historical data download ID 54. 2024-06-19 09:43:39.011 | Real-time Intraday chart data file updates started for 6NU24_FUT_CME 2024-06-19 09:43:39.012 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\6NU24_FUT_CME.scid. Thread ID: 16644 2024-06-19 09:43:39.012 | Intraday chart data file opened for 6NU24_FUT_CME 2024-06-19 09:43:39.012 | HD Request # 54 | Enabling Intraday chart updating for symbol. 2024-06-19 09:43:39.012 | 2024-06-19 09:43:39.012 | No download requests in the queue to start downloads for. 2024-06-19 09:43:39.130 | Chart #4 has tagged chart #5 for full recalculation. Chartbook: Silver.Cht 2024-06-19 09:43:40.675 | MCLQ24_FUT_CME [CV] 2 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Equities.Cht 2024-06-19 09:43:40.996 | MCLQ24_FUT_CME [CBV] Daily #1 | Performing a full recalculation because it has been tagged. Chartbook: Equities.Cht 2024-06-19 09:43:41.320 | SIU24_FUT_CME [CV] 5 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Silver.Cht |
[2024-06-19 15:14:54] |
We are not seeing any issues in the Message Log. What exactly is the problem you are having?
