Date/Time: Fri, 18 Oct 2024 06:02:15 +0000
DOM
View Count: 134
[2024-06-17 19:49:23] |
User186641 - Posts: 3 |
Hi, My DOM is not working properly. I can't see all the orders or numbers of position traded for forex. Can you advise me on why this is? Thanks, |
[2024-06-17 19:50:26] |
John - SC Support - Posts: 35333 |
If you are referring to the Market Depth, then the reason for this is that the FOREX data we get from FXCM does not include Market Depth data. You can, however, get Market Depth data for the currency futures for the CME Group, and this is available with our Delayed Streaming data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
