Date/Time: Sat, 04 Jul 2026 04:55:14 +0000
hello
View Count: 451
| [2024-06-17 18:52:48] |
| User927951 - Posts: 1 |
Hello ,can I connect to Rithmic with the 36 dollar package?
| [2024-06-17 18:55:29] |
| John - SC Support - Posts: 47017 |
It depends on which $36.00 package you are referring to. We have the "Base Advanced" and the "Integrated Standard" packages that are both $36.00. In order to be able to connect to trading an data services, you need to be on one of the "Integrated" packages. Refer to the information on the packages at the following link: Description of Service Packages and Pricing: Packages It does not matter which of the Integrated packages you are on to connect to Rithmic. Any of the packages will allow for connectivity to any of the data and trading services Sierra Chart can connect to. And for when you go to make the connection, the instructions to connect to Rithmic are at the following link: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
