Date/Time: Tue, 22 Sep 2026 11:12:32 +0000
Setting up multiple trade providers and prop firms
View Count: 3341
| [2024-06-17 15:08:28] |
| TriStar Trading - Posts: 200 |
I am planning on trading Dorman, Apex, and possibly some other prop firms. I have read the doco concerning this but am still unsure as to how to proceed. I'm thinking instances will not work due to the instance using the same trade service provider. Should I be using multiple installs of SC instead with each one connected to it's appropriate trade service provider? I assume all the data still comes Denali correct? Thanks!
| [2024-06-17 17:09:50] |
| John - SC Support - Posts: 47955 |
Yes, this is exactly what you need to do. Refer to the following for how to install additional Sierra Chart instances: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart I assume all the data still comes Denali correct?
Yes, this is correct - to an extent. The exchanges only allow for 3 separate instances on a single computer to be able to get the data at the same time. If you have more than 3 trading services you want to connect to at the same time, then you could use a second computer and have another 3 installations on that computer, but you do have to pay the exchange fees a second time for this. Refer to the information at the following section: Denali Exchange Data Feed: Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
