Date/Time: Wed, 27 Nov 2024 08:43:02 +0000
Ask/Bid difference bars
View Count: 957
[2014-08-22 16:12:16]
User13995 - Posts: 5
This study is showing gaps on some printed bars (not all of them)..to clarify some bars are staring lower than the zero line and some are starting off higher than the zero line..this is a new issue for me...can you help??
[2014-08-22 16:30:14]
Make sure you have tick by tick data configuration:
https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php
Refer to this section here about IQ Feed:
DTN IQ Feed Data Service: Tick Data Limitation during Primary Session Hours
Consider using the Sierra Chart Real-time and Historical Exchange Data Feed instead so there is no historical tick data limitation:
Sierra Chart Exchange Data Feed
