Date/Time: Sun, 24 Nov 2024 07:01:36 +0000
Backup copy while running?
View Count: 207
[2024-06-17 08:44:15] |
User745789 - Posts: 313 |
I have an app which makes a zipped copy of my Sierra Chart folder every day at the same time (excluding the data folder). That zipped file is then uploaded to my cloud service. This is my backup. My question: does it matter if Sierra Chart is running while the zip copy is made of the SC folder? Will all files in the SC folder be included in the zip if SC is running? |
[2024-06-17 09:14:23] |
Sierra_Chart Engineering - Posts: 17154 |
It is fine to do a backup while Sierra Chart is running but you want to set Chartbooks and Spreadsheets to be automatically saved: General Settings Window: Auto-Save Chartbooks (Global Settings >> General Settings >> Charts >> Chartbooks) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
