Date/Time: Tue, 22 Sep 2026 09:17:50 +0000
Rollover contract - the correct way
View Count: 2517
[2024-06-17 08:25:20]
VLiviu - Posts: 223
Hi dear SC
Please advice whats the correct way to rollover a contract.
My S&P broke this morning after manual rollover.
Please see attached.
imageScreenshot 2024-06-17 042201.png / V - Attached On 2024-06-17 08:25:07 UTC - Size: 155.73 KB - 250 views
[2024-06-17 10:19:31]
VLiviu - Posts: 223
forgot to mention that I am connected to your trading evaluator server
[2024-06-17 12:27:59]
Sierra_Chart Engineering - Posts: 24928
Two things about this. In order for order fills to match, you cannot use one of the Back Adjusted options:
Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options
And set this to Yes in Chart Settings:
Chart Settings: Load Order Fills for Multiple Futures Contracts (Chart >> Chart Settings >> Trading menu)
[2024-06-17 12:35:12]
VLiviu - Posts: 223
Got it, thanks!
So, how do I choose my rollover? What should I have choose from that menu?
-date rule?
-volume based?
or I can select "volume based, back adjusted and ignore the messed orders?
[2024-06-17 12:36:40]
VLiviu - Posts: 223
All I need is the chart to be correct, I can hide the old orders from old dates
Date Time Of Last Edit: 2024-06-17 12:36:58
[2024-06-17 12:44:44]
After this, use Date Rule Rollover.
[2024-06-17 13:02:02]
VLiviu - Posts: 223
Thanks!
[2024-06-17 16:22:51]
VLiviu - Posts: 223
after following your steps, I got this (attached)
Is this correct?
imageScreenshot 2024-06-17 042201.png / V - Attached On 2024-06-17 16:22:46 UTC - Size: 24.33 KB - 190 views
[2024-06-17 17:26:48]
John - SC Support - Posts: 47955
Yes, that is correct. It shows you the actual prices of the contracts. There is a difference in price between the old contract and the new one, which is why you have the gap.
[2024-06-17 17:42:01]
VLiviu - Posts: 223
Appreciate it, John!
