Date/Time: Sun, 24 Nov 2024 07:58:49 +0000
Charts stuck at 6th june
View Count: 161
[2024-06-16 11:46:26] |
User188445 - Posts: 11 |
Hi, My charts seems to be stuck on 6th june. I tried connecting and disconnecting the feed. I tried to delete all data and download. I tried changing the broker but nothing happened. Please help. Also if i open a new chart that seems to work fine in the same chartbook but all the other chartbook are not working properly. |
[2024-06-16 14:42:36] |
Sierra_Chart Engineering - Posts: 17154 |
Most likely the symbols are not correct. Translate them with this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
