Date/Time: Thu, 19 Sep 2024 21:41:34 +0000
Can I show the volume on the DOM ladder window?
View Count: 1091
[2014-08-22 14:57:13] |
trial04225 - Posts: 6 |
Can I show the volume on the DOM ladder window somewhere?
[2014-08-22 17:15:21] |
Are you referring to the daily trade volume?
[2014-08-22 18:45:08] |
Yes. volume for today
[2014-08-22 18:52:05] |
You can view that through Window >> Current Quote Window.
[2014-08-25 19:29:54] |
User14266 - Posts: 225 |
From DOM window... Chart > Studies > then add VbP study. |
[2014-08-26 14:53:41] |
Yes, that window has it, its better if no need to open another window. :) User14266, thanks for that, its volume by price. |
