Date/Time: Sun, 24 Nov 2024 07:39:00 +0000
HTTP Post Requests
View Count: 202
[2024-06-16 07:15:06] |
limitlesstrevor - Posts: 3 |
I'm looking for a setting that allows you to configure HTTP POST requests to an external flask program. I've seen online that there is a built in setting to do this but I can't seem to find it. My goal here is to send a post request to a flask program when I enter/exit a trade, and then have that program execute using that data. If there is another way to go about doing that I'm open to that too. Thanks
[2024-06-16 14:43:46] |
Sierra_Chart Engineering - Posts: 17154 |
It is the URL parameter that specifies where the request to goes. Refer to: sc.MakeHTTPPOSTRequest() Just set that as required. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
