Date/Time: Sun, 08 Sep 2024 01:56:03 +0000
bracket order
View Count: 170
[2024-06-16 03:04:57] |
User953115 - Posts: 4 |
I can configure a bracket order to enter the market with a 2 lot limit order, common stop and two different targets. Is it possible to also move the common stop to 1 point (4 ticks) less than break even if the market moves 4 points in my favor? |
[2024-06-17 14:17:30] |
Use the "Move to Breakeven" option on the Attached Orders tab for the Stop. You can set it to occur with an "Offset in Ticks Triggered", and you can set a Breakeven Offset along with the trigger offset. Refer to the following: Attached Orders: Move to Breakeven for Stop For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
