Date/Time: Sun, 24 Nov 2024 06:33:47 +0000
Heiken-Ashi last/close price settings
View Count: 182
[2024-06-15 16:30:35]
User933326 - Posts: 6
I understand the two options for displaying the last/close price vs the calculated value. However, I am wondering if you have considered, or would consider, adding an option to use both options simultaneously.
For example, I would like the last price line to show the actual price, but would like the close price to be the calculated value as the bar is being formed. I am transitioning from a different platform whose HA candles work in this way and I have become very used to it. Thanks for the consideration.
[2024-06-17 09:40:18]
Sierra_Chart Engineering - Posts: 17154
Create your own custom study to do what you need. Refer to:
How to Build an Advanced Custom Study from Source Code
The source code for the Heikin Ashi study is provided.
