Date/Time: Sun, 24 Nov 2024 07:40:38 +0000
Compile Error with IBPT_FLEX_RENKO_INV
View Count: 209
[2024-06-15 16:16:04]
ertrader - Posts: 672
Hi Support... the following code returns an error despite being accurate to the documentation.
It appears that the variable IBPT_FLEX_RENKO_INV (Inverse Renko) has not been set up within SierraChart.
When changed to IBPT_FLEX_RENKO_IN_TICKS, it compiles correctly.
Code:
        n_ACSIL::s_BarPeriod NewBarPeriod;
        NewBarPeriod.ChartDataType = INTRADAY_DATA;
        NewBarPeriod.IntradayChartBarPeriodType = IBPT_FLEX_RENKO_INV ;
        NewBarPeriod.IntradayChartBarPeriodParameter1 = 1;
        NewBarPeriod.IntradayChartBarPeriodParameter2 = 1;
        NewBarPeriod.IntradayChartBarPeriodParameter3 = 11;
        NewBarPeriod.IntradayChartBarPeriodParameter4 = 6;
        sc.SetBarPeriodParameters(NewBarPeriod);
Error:
error: 'IBPT_FLEX_RENKO_INV' was not declared in this scope; did you mean 'IBPT_FLEX_RENKO_IN_TICKS'?
Documentation:
sc.SetBarPeriodParameters()
Can you please take a look?
Date Time Of Last Edit: 2024-06-15 18:39:16
[2024-06-15 18:38:01]
In doing a search in scstructures.h, it appears the correct value is: IBPT_FLEX_RENKO_IN_TICKS_INVERSE_SETTINGS
The documentation just needs to be updated to be accurate.
[2024-06-16 03:29:42]
Sierra_Chart Engineering - Posts: 17154
This has been corrected in the documentation.
[2024-06-16 03:49:52]
I'm not seeing the update... it still says IBPT_FLEX_RENKO_INV = 15 when it should say IBPT_FLEX_RENKO_IN_TICKS_INVERSE_SETTINGS
I have refreshed a few times.
Date Time Of Last Edit: 2024-06-16 03:52:48
[2024-06-16 04:39:49]
It was actually not yet released. But we now released the page.
