Date/Time: Fri, 18 Sep 2026 10:26:46 +0000
Chart values window or Tool values window
View Count: 1446
[2024-06-15 11:54:33]
VLiviu - Posts: 223
Hi SC support,
Quick question please, is it possible to customize the "chart values" or the "tool values" windows to show only specific values?
For example, in the attached pic, I only wanna see the VBP chart values section with specific fields.
Thanks!
imagechart_values.png / V - Attached On 2024-06-15 11:54:25 UTC - Size: 51.92 KB - 262 views
[2024-06-17 14:07:34]
John - SC Support - Posts: 47930
For that particular item, there is only an "all or nothing" option. The Volume by Price has an Input for "Display Data in Chart Values Window" to control this. Refer to the following:
Volume By Price Study: Display Data in Chart Values Window
Apart from this specific item for the Volume by Price study, if there are specific subgraphs in a study that you do not want to see in the Tool/Chart Values Windows, then you can control this on Subgraphs tab for the study. Refer to the following:
Chart Studies: Subgraphs Tab >> Display Name and Value in Chart Values Windows
Also refer to the following and the item below it, that lets you control which of the Main Price Graph items you can have displayed in the Values Windows:
Chart Settings: Display Main Price Graph Values in Values Windows (Chart >> Chart Settings >> Display >> Chart Values menu)
