Date/Time: Sun, 24 Nov 2024 07:32:39 +0000
The prices for S&P 500 are Not a same on all charts
View Count: 159
[2024-06-14 16:57:14]
Dorel - Posts: 5
Morning,
Thank you for your response.
I went through all steps you provided and activated live trading, I have also made the roll over for the S&P 500 to the current one as of June 2024 which I believe is F.US.EPM24 (as below screenshots show). Is this correct? Is this the symbol I need to have?
Also, if we look at both Sierra Chart windows in the same below screenshot, you will notice a price of $5427.50 on the DOM and a different price of $5434.75.
Another difference I spotted is that on the DOM window on the top bar the name is F.US.EPM24[M] and on the VWAP is F.US.EPM24[CBV][M]
Could you please tell me why is this difference? Logically is should have the same price on all windows right? (DOM window, VWAP, Footprint etc)
So my questions are:
1.  Is this the correct symbol?
2.  What do I have to do to have the same price on all charts?
I look forward to hearing from you.
attachment19. No, the prices are the same on the charts.pdf - Attached On 2024-06-14 16:56:42 UTC - Size: 152.56 KB - 72 views
[2024-06-14 17:06:45]
1. Yes, this is the correct symbol. M is the current front contract for the E-Mini S&P 500 Index Futures from the CME Group.
The [CBV] indicates that you have the chart setup as a "Continuous Volume Based Back-Adjusted" chart. Refer to the following:
Continuous Futures Contract Charts: Text Indicator Description Table
2. Most likely the chart on the right is not scrolled to the end, so you are viewing the data back in time. In addition, it looks like you have the option for "Lock Fill Space" enabled. Refer to the following:
Working With Charts: Scrolling The Chart and Right Side Fill Space
