Date/Time: Sun, 24 Nov 2024 07:40:17 +0000
Using SierraChart -- moving my footprint (Numbers Bars) chart
View Count: 204
[2024-06-14 16:00:11] |
User760022 - Posts: 8 |
Hi, For some reason, I unable to move my footprint chart anymore. I'm guessing that I clicked a setting without realising. My footprint chart stays mainly fixed now and I have to use the scroller to move it. Do you think you guys could help? Also, is it possible to have split charts on Sierra chart. I'd like to have spy then the footprint es and the Dom. Is that possible to put that all in one screen? Thanks/Regards H |
[2024-06-14 16:57:23] |
You state that you can use the "Scroller" to move the chart. What is meant by "scroller"? is that the scroll wheel or the scroll bar? How exactly are you trying to move the chart that is not working? -- With regards to "split charts", refer to the following: Add Additional Symbol Window, CB and CW Menus: Tile Horizontally (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-14 18:43:27] |
I am unable to move the chart without have to use the horizontal scroll bar below the time zone and horizontal axis. Before I was able to do so by clicking anywhere on the chart. Also, does sierra chart have spy pre-market and after-hour candles? Thanks/Regards Haseeb |
[2024-06-14 18:46:35] |
For some reason, it works now. I'm sorry in the morning it wasn't working. I'm guessing it might've been a bug or my laptop. Thanks/Regards I will look into the link you also sent to add additional symbols. Thank you for that! Best Haseeb |
[2024-06-14 18:55:03] |
We do have 24 hour data for SPY (and other U.S. equities). You can get the delayed streaming data by opening a chart for the symbol. If you want real-time data, then you can setup the "U.S. Equities Consolidated Tape" exchange by following these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
