Date/Time: Sun, 08 Sep 2024 01:32:56 +0000
Broken TEXT TOOL
View Count: 221
[2024-06-14 14:33:36] |
User68117 - Posts: 65 |
1) I have a request regarding the TEXT TOOL. When I write some text in the graph and subsequently want to change the font size, for example, it doesn't work for me. Elections don't work. I try everything possible in the text properties, but the text size is still the same. Even the Font (Action) option does nothing. 2) I have to say that the recent changes in Sierrachart, especially the redesign of various settings, are not good at all. For example, the initial setup in the Trade Activity Log was simple, fast and clear. Now after converting it to a pop-up window, it's totally confusing and completely useless. I am not at all satisfied with these changes, which very often have errors and work poorly or not at all. |
[2024-06-14 15:55:41] |
1) Update to the latest release. These items have been fixed. 2) There are many reasons why we are making these changes. We are sorry that there were issues when it first rolled out, but those have been fixed now. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-14 21:35:45] |
User61168 - Posts: 381 |
my 2 cents on #2.... Indeed the new UI is inconvenient and not very user-friendly requiring too many clicks. Could I please request these features if there is no compromise on platform performance? 1) "auto-apply" every time a value is changed instead of forcing us to hit apply after each change. 2) use of mouse scroll wheel to change values 3) ability to sort by clicking on column header Regardless, I have noticed significant performance improvements with TAL on the new design so kudos for that! I am not at all satisfied with these changes, which very often have errors and work poorly or not at all.
- I have not encountered any issues or errors. It is VERY stable. Date Time Of Last Edit: 2024-06-14 21:36:30
[2024-06-17 13:54:02] |
Sierra_Chart Engineering - Posts: 16292 |
2. Refer to: Trade Activity Log: Notes About New Trade Activity Log Window If there any issues let us know but we are aware of none in the current version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
