Date/Time: Wed, 27 Nov 2024 10:45:55 +0000
rockwell studies error message
View Count: 1483
[2014-08-22 14:24:20] |
User70152 - Posts: 20 |
I am trying to apply rockwell studies by going into analysis, choosing rockwell studies sc and getting this error message. I am on 1170 version. This message is fairly long with same repeatation therefore posting just a snippet Launching C:\SierraChart\SierraChartTransActMA\SpreadsheetFileConverter.exe with parameters: "C:\SierraChart\SierraChartTransActMA\Data\Rockwell studies SC.scwbf" "Rockwell studies SC.scss" 38669164 -culture=1033 | 2014-08-22 10:14:47 Failed to launch C:\SierraChart\SierraChartTransActMA\SpreadsheetFileConverter.exe. Windows error code 2: The system cannot find the file specified. | 2014-08-22 10:14:47 Unable to open C:\SierraChart\SierraChartTransActMA\Data\Rockwell studies SC.scwbf because the spreadsheet file conversion failed. | 2014-08-22 10:14:47 |
[2014-08-22 17:14:26] |
Update Sierra Chart by selecting Help >> Download Prerelease (Old Spreadsheets). You need to be using the version of Sierra Chart that has support for Old Spreadsheets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-22 17:14:53
[2014-08-24 11:37:27] |
I upgraded to prerelease 1176(old spreadsheet). New error message is show below. Indicators working fine though. I have also noticed this message in any study you choose. Failed to get the Advanced Custom Study function address for scsf_MouseMenuExample in SierraChartStudies.dll. Error: Windows error code 127: The specified procedure could not be found. | 2014-08-24 07:32:50 Date Time Of Last Edit: 2014-08-24 19:18:06
[2014-08-24 23:19:38] |
This issue has now been fixed. Update Sierra Chart by selecting Help >> Download Prerelease.
