Date/Time: Sun, 24 Nov 2024 07:33:29 +0000
The downloader doesnt work: MD5 for file does not match
View Count: 214
[2024-06-14 11:46:31] |
qpq - Posts: 2 |
Hello, just to let you know I saw this post and I have the same problem: Problem updating Sierra Chart - MD5 for file does not match file SierraChart_64.exe This is what I see: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=101909 I have no idea if you can see the screenshot from that link so I uploaded it here too: https://ibb.co/PZFM5Nf Im now downloading from the zip as suggested in that post even though its very slow (about 6-20Kb/s). Greetings |
Attachment Deleted. sierra chart.png / V - Attached On 2024-06-14 11:41:54 UTC - Size: 283.08 KB - 44 views |
[2024-06-14 14:54:35] |
Sierra_Chart Engineering - Posts: 17154 |
You may be affected by the problem described here: Sierra Chart Internet Connectivity Related Issues We are changing the Internet connectivity this evening for our web services. Hopefully this will resolve the problem. Please try downloading Sierra Chart again tomorrow morning. Use this installer: https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe And let us know if the download speed is much better. We need to know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-14 14:55:00
[2024-06-15 08:45:03] |
Here is a faster link to access the zip file: https://download2.sierrachart.com/downloads/ZipFiles/SierraChart2646.zip Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-15 13:38:21] |
qpq - Posts: 2 |
Hello, everything is working fine today. No problem with the speed at all. Greetings & thanks |
