Date/Time: Sun, 24 Nov 2024 07:59:21 +0000
Replay Control Panel
View Count: 149
[2024-06-14 10:10:37] |
gui_spadini - Posts: 1 |
Hi, The replay control panel is not popping up for me anymore. This issue started today. When I click on the Replay Chart (Control Panel), nothing happens. Thank you |
[2024-06-14 15:35:44] |
Select "Chart >> Replay Chart >> Reset Replay Control Panel Window". Refer to the following: Chart Menu: Reset Replay Control Panel Window (Chart >> Replay Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
