Date/Time: Sun, 24 Nov 2024 09:07:48 +0000
Turn-Off Chart DOM Price Collapsing/Condensing?
View Count: 177
[2024-06-13 18:51:55]
User261655 - Posts: 28
On my chart DOM, the price ladder condenses/collapses at a certain scale point. So instead of this:
5435.00
5434.75
5434.50
5435.25
5434.00
I'll just see:
5435.00
5434.00
etc
But that leads to blank spaces while all of the DOM quantities still appear.
Is there a way to turn this off so that prices behave the same way as the DOM quantities? I know that the easy answer is "don't scale your DOM down" but I wonder if there's another solution that I'm missing.
Thanks, as always!
[2024-06-13 20:17:18]
You can force a specific scale increment, but the numbers are still going to "collapse" together when you scale your chart to show a wider range of prices. There is no way around this, as we are not going to have prices overwriting each other in this case. But this setting can be helpful for the opposite situation - where you are showing a smaller range of values, so you will only get the increment you want. Refer to the following:
Chart Scale and Scale Adjusting: Scale Increment (Scale Settings)
