Date/Time: Fri, 18 Oct 2024 05:54:23 +0000
Volume data is not showing correctly as ThinkOrSwim
View Count: 214
[2024-06-13 18:31:23] |
Ragy - Posts: 29 |
Hello - My volume on Sierra chart is off by big margin when compared to ThinkOrSwim and Webull. For example, today's chart for SMCI 5 min, the opening candle on Sierra shows a total volume of 92K, while TOS showing 231K and Webull showing 408K. I did the same test on AAPL and the results were not consistent. As you can see Sierra is always showing a lower volume. Is there a reason why is that? |
Private File |
[2024-06-13 18:38:53] |
John - SC Support - Posts: 35333 |
You are getting the data from our NASDAQ TotalView exchange. This exchange only has volume and price information for the NASDAQ trades that occur. Refer to the following: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes If you want to have the consolidated volume, then you would need to use our "U.S. Equities Consolidated Tape" exchange. Refer to the following: US Stock/Equities Consolidated Tape Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-17 16:13:04] |
Ragy - Posts: 29 |
Is there U.S. Equities Consolidated Tape with Depth? Or how can I see depth L2 data while also using U.S. Equities Consolidated Tape
Date Time Of Last Edit: 2024-06-17 16:19:08
[2024-06-17 17:23:48] |
If you have both the "U.S. Equities Consolidated Tape" and the "NASDAQ TotalView" exchanges active, then you can use a symbol with the suffix of _MBO (e.g. TSLA_MBO), that will give you the Pricing and Volume from the U.S. Equities Consolidated Tape wit the Market Depth data from the NASDAQ TotalView.
[2024-06-17 19:14:46] |
Ragy - Posts: 29 |
Where can I find TSLA_MBO? Is it under "U.S. Equities Consolidated Tape"? Or I just simply type "TSLA_MBO" in the symbol field?
[2024-06-17 20:42:10] |
You need to type in the symbol, such as "TSLA_MBO".
