Date/Time: Sun, 24 Nov 2024 07:48:04 +0000
Session Times Advice
View Count: 230
[2024-06-13 15:33:48]
tntrader1 - Posts: 2
Hello...I am new to Sierra Charts and have a TPO chart created. Everything is working as expected with one exception. From what I think I've seen on Sierra Charts in the past, regular hours show with capital letters and after hours show with lower-case letters (both starting with A,a respectively). My TPO chart appears to carry forward the capital letters into the after hours session and then pick up with the lower-case after 'Z'. My Intraday Chart does start with 'A' for the firt time block every day, as expected but it appears to be a mix of upper and lower-case into the Evening Session. Is this expected or have I set something wrong (highly likely)?
I am in the central time zone and have my times set as follows in Chart Settings...
Intraday Chart Session Times
Session Start Time: 08:30:00
Session End Time: 15:00:00
Use Evening Session: YES
Evening Start Time: 17:00:00
Evening End Time: 08:29:59
[2024-06-13 16:13:03]
Set the Input on the TPO study for "Letters Always Start At Primary Session Start Time" to "Yes". Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Letters Always Start at Primary Session Start Time
[2024-06-14 14:10:10]
I had that set to YES prior to creating the TPO chart.
[2024-06-14 15:52:06]
Then at the primary session time, the letters should be starting at 'A' or whatever the first letter is in your list of letters in the TPO Input.
Are you seeing something else? If so, then give us an image of what you are seeing by following these instructions:
