Date/Time: Sun, 24 Nov 2024 07:47:00 +0000
[User Discussion] - DataBento to .depth and .scid
View Count: 236
[2024-06-13 14:18:45]
skalaydzhiyski - Posts: 58
Hi guys,
Is it possible (in theory) to convert databento data dump (depth + tick data) for a given date say (1 March 2020) into a corresponding .depth and .scid files for a ticker for this date so that I can get market replay through sierra for dates far back in history.
The databento dump is in csv format. If I can encode the data into .depth and .scid binary files will this mean Sierra will be able to read from them as if it was a normal day?
As in are there any restrictions that prevent sierra from doing DOM replay for dates that are further back in history ?
All the best,
Spas
[2024-06-14 15:40:36]
Actually I have figured out how to do it, please don't bother with the Support Request,
All the best
