Date/Time: Sun, 08 Sep 2024 00:18:42 +0000
Filter Chart Dom
View Count: 119
[2024-06-13 12:32:09] |
kam2001 - Posts: 79 |
the chart dom is really cluttered as you can see in attached, can functionality to filter the size be added !! ..This has been asked multiple times over the years to not avail..
![]() Attachment Deleted. |
[2024-06-13 13:31:08] |
Sierra_Chart Engineering - Posts: 16292 |
Filter the size of what? We do not know what you are referring to. There is this setting to filter the size of the market depth values: Chart Settings: Chart DOM/DOM Graph: Only Display Market Depth Above/Equal Quantity (Chart >> Chart Settings >> Market Depth menu) And there is also a filter for the market by order data: Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-02 15:12:54] |
it's exactly as asked here..filter the size of bid and offer on market depth on a chart Filter Dom Graph on Chart |
