Date/Time: Sun, 24 Nov 2024 08:20:36 +0000
delayed data
View Count: 118
[2024-06-13 12:28:50] |
kam2001 - Posts: 79 |
Hi I have activated "CME with Market Depth for non-professional Trading accounts" and but my data on NAsdaq Futures(NQM24-CME) is delayed by 10 mins approx..
[2024-06-13 14:05:58] |
Sierra_Chart Engineering - Posts: 17154 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
