Date/Time: Sun, 24 Nov 2024 08:51:40 +0000
The services that are not activated
View Count: 190
[2024-06-13 05:33:00]
cjmitch111 - Posts: 6
Can you assist me with unsubscribing to the current services I currently have and dont use. I only use FUTURES NQ Market Depth Level 2 Data and QQQ real time data
[2024-06-13 14:07:31]
SC Support - Posts: 1895
Hi there, so you want to remove CFE Data (CBOE Futures Data, VIX Futures)?
Which Sierra Chart Features do you use, Numbers Bars ("the Footprint"), TPO Charts ("Market Profile")?
[2024-06-13 16:43:12]
I only use numbers bars and market profile
[2024-06-13 16:51:24]
In that case your analysis is volume focused, so you should really have the Consolidated Tape US Equities Feed because that aggregates the Trading Volume for each stock, etf across the 19 venues, whereas Nasdaq TotalView will just show you what is happening on the Nasdaq Venue.
Note that for stocks the Nasdaq TotalView Feed is our only Market Depth Feed.
Do you want us to remove CFE Data (CBOE Futures Data, VIX Futures)?
