Date/Time: Sun, 24 Nov 2024 08:19:35 +0000
Open Instance that was closed
View Count: 148
[2024-06-13 01:06:29] |
User303857 - Posts: 74 |
Hello Support Is there a way to open an instance after it was closed ? Other that shutting down the entire system and restarting them all? Thank You |
[2024-06-13 14:42:58] |
There is not a way to open a specific instance once it has been closed. But keep in mind that the system is setup to open the lowest numbered instance that is not already running. So if you have instance numbers 2, 3, 4, and 5 running and close instance 4, if you select "File >> New Instance" then instance 4 will be the one opened.
