Date/Time: Sun, 24 Nov 2024 07:38:47 +0000
MP color change
View Count: 165
[2024-06-13 00:38:48] |
User553413 - Posts: 60 |
is it possible that you could make it possible to change the color of indiidual market profiles so that I can identify the ones that are merged from the ones that aren't. If not, is there some way to tell them apppart other than the date, and the size of the market profile. I want to idenify the merged market profile with color change or a label.
[2024-06-13 14:40:45] |
The one item that is available that will give you an indication is the Chart Values that you can display above, below, or at the bottom of the chart. Within these is an option for "Period Time Span" which will give you an indication of whether the profile has been merged or not. Refer to the following and the 3 items below it: Time Price Opportunity (TPO) Profile Charts: Show Chart Values On Profile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-14 13:08:41] |
that's not what I meant. But I will do the long way and figure out which MP are merged and which ones are not merged. I have another question. I use the global trade position limit to limit my position size until I get more consistency. I also want to use the trade copier to trade multiple accounts, and use 3X multiplier for one of the accounts. Is it possible to have seperate trade position limit for two differenta accounts? because I found that the trade position limit is the same for all accounts, which makes it more difficult to use the trade coppier and use a trade multiplier of more than one> Please let me know if you need me to rephrase my question. |
[2024-06-14 15:49:33] |
We were just giving you an option for how to view the information. There is no coloring option available. Is it possible to have seperate trade position limit for two differenta accounts?
There is just the one option for the Trade Position Limit, so you would need to make this the largest value for the positions you are taking. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-14 17:56:31] |
Understood. But I have one problem with the risk parameters I set before trading. I end up breaking the rules and changing the setting in the middle of trading session to allow me to increase my daily loss limit or to increase my position size. I would like to lock the settins during the trading period or during certain period in the day so that I can't make those changes in the middle of the trading session. It's crucial to staying consistent enough to allow me to stick around for the long run. Is there a way to lock the settings for certain period during the day so that I can't make any changes to my risk management plan?
Date Time Of Last Edit: 2024-06-14 17:58:44
[2024-06-14 18:51:57] |
There is nothing built into the system that will not allow you to override the settings. For instance, you can create a custom study to control this, but all you would need to do is remove the study and you could continue to trade. The only way that something like this will work for what you are stating is if your broker controls this for you. Check with your broker to see if they have the ability to do this for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
